Browse Forums Building A New House 1 Mar 10, 2021 5:58 pm Hello knowlegeable building gurus. we are planning to build a 2 story home in sydney, wanting a double brick concrete slab but the cost difference seems to be huge and may end up with brickveneer(which i am not keen on). how much more should a Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ concrete slab cost anyway? the grey shaded area is going to get wasted if we have to go BV(its the roof of the kitchen loune on ground floor), had dreams of building a balcony jungle garden, is there any way i can still get that with a BV?any addition we can do to make it strong enough/waterproof enough...hope someone can save my green outside area dream... Re: is balcony(to be a green space with lots of plants) poss 2Mar 10, 2021 6:43 pm You'll need an engineered suspended concrete slab on Steel Columns ie Typical column and beam/slab construction, the timber stud frames adds nothing structural... OT, If your block is small with spectacular views, then I highly recommend 2S part Double brick, structural steel frame , suspended slabs with roof top garden. $150-200/m2 + extras Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: is balcony(to be a green space with lots of plants) poss 3Mar 10, 2021 6:52 pm StructuralBIMGuy You'll need an engineered suspended concrete slab on Steel Columns ie Typical column and beam/slab construction, the timber stud frames adds nothing structural... OT, If your block is small with spectacular views, then I highly recommend 2S part Double brick, structural steel frame , suspended slabs with roof top garden. $150-200/m2 + extras Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ since the whole concrete slab is adding so much more money we are not in a position to take loan for, is there any way we can make the portion where the balcony garden is strong?below the balcony is the main kitchen area thats why scared of water leaks..hmmm any way to make that specific area able to support the balcony not the whole first floor...dont know if any thing like that is even possible? brick veneer $650000, concrete double brick $800000 hmmm approx Re: is balcony(to be a green space with lots of plants) poss 4Mar 10, 2021 8:47 pm mumstheword StructuralBIMGuy You'll need an engineered suspended concrete slab on Steel Columns ie Typical column and beam/slab construction, the timber stud frames adds nothing structural... OT, If your block is small with spectacular views, then I highly recommend 2S part Double brick, structural steel frame , suspended slabs with roof top garden. $150-200/m2 + extras Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ since the whole concrete slab is adding so much more money we are not in a position to take loan for, is there any way we can make the portion where the balcony garden is strong?below the balcony is the main kitchen area thats why scared of water leaks..hmmm any way to make that specific area able to support the balcony not the whole first floor...dont know if any thing like that is even possible? brick veneer $650000, concrete double brick $800000 hmmm approx Hi Mumstheword we are doing a project with a situation similar to what you are describing and using Sycon Secura Exterior flooring. Link below https://www.jameshardie.com.au/productr ... r-flooring I have also put a link to an installation video. Its a fraction of the cost of a suspended slab https://www.youtube.com/watch?v=0Voe8wjHYNs There are also other light weight options available such as Hebel Powerfloor etc PM me if you need more information Cheers S Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: is balcony(to be a green space with lots of plants) poss 5Mar 10, 2021 9:22 pm Hebel powerfloor surely you jest... LOL, yet another product that couldn't crack the WA market material cost comparisons Concrete $200/m3 + temp. formwork costs hebel powerfloor $900/m3 + permanent structural beams costs Just curious where is the engineering and cost savings? Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: is balcony(to be a green space with lots of plants) poss 6Mar 10, 2021 9:39 pm the must charge a fortune to ship it over to WA. Its made here in Gosford and we dont pay anything near that. BTW our concrete costs are a lot more expensive then yours circa $350-400/sqm for suspended. I would imagine Melbourne and Adelaide also have different rates. Yep its hard to compare between states. What works over your way doesn't necessarily work over here and vice versa. So its hard to judge or be critical. Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: is balcony(to be a green space with lots of plants) poss 7Mar 10, 2021 10:16 pm SejaeD Yep its hard to compare between states. What works over your way doesn't necessarily work over here and vice versa. So its hard to judge or be critical. IMO, Only because they make it hard for you to compare I look at it this way any building material that requires further manufacturing and transportation adds 4-5 times the base material cost I'd rather pay the guys more on site to manufacture and erect. tho not always suitable for all jobs Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: is balcony(to be a green space with lots of plants) poss 8Mar 11, 2021 6:21 am StructuralBIMGuy SejaeD Yep its hard to compare between states. What works over your way doesn't necessarily work over here and vice versa. So its hard to judge or be critical. IMO, Only because they make it hard for you to compare I look at it this way any building material that requires further manufacturing and transportation adds 4-5 times the base material cost I'd rather pay the guys more on site to manufacture and erect. tho not always suitable for all jobs Cheers Chris Chris I think we would get along, as I agree with your building principles. It's old school but hey there are still Roman buildings standing after 2000 years and all that concrete was formed and poured on site! I come from a background of building hundreds of warehouses where we formed and poured all our own panels on site to control quality rather then relying on precast panels built in a factory. The only problem with our way of thinking is that not everyone can afford to build this way, and sometimes some materials are cheaper from the mass produced factory, so we have to be pragmatic to peoples budgets. We are using Hebel a bit at the moment as it's cheap and in Sydney and with land prices being so high we are finding that customer's budgets are tight. If installed correctly its not a bad product but would I choose it over rendered brick, absolutely not if money were no object. Have a great day S Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 4229 First time building 2 storey home in NSW. Below Current plan have separate balcony. But thinking to do a multipurpose lounge with balcony (kind of sunroom) in first floor… 0 4269 Well you won't get cooked by the afternoon sun when sitting out on the balcony on a summers afternoon but you won't have much to look at besides the neighbours… 4 3200 |
