Browse Forums Building A New House 1 Mar 10, 2021 11:18 am Hi All, New to the forum I'm in the initial stages of really seriously contemplating a knock down re-build. I want to knock down my old fibro house and build a new house and potentially a granny flat as well. I have a few questions and was hoping for some insight/help. My block of land is 13.411 x 33.528 = 449.64 sq meters This is according to the Deposited Plan (DP) document. This is just shy of 450, which is the minimum amount to build a granny flat. Is it worth getting a surveyor to re-assess the size of the land or is the DP generally spot on? Or is there any leeway with it being 0.36 sq meters short of 450 by the council? ----- Is a granny flat also included in the floor space ratio? In my council area, you are only allowed 45% of your land size, so my floor space allowance is 202 sq meters. If the granny flat is included in the total FSR, then I probably scrap the whole granny flat idea as 202 is not much to work with and I will lose quite abit of floor space in the main house. Thanks in advance Re: Land Size / Granny Flat / FSR 2Mar 10, 2021 10:25 pm Is it worth getting a surveyor to re-assess the size of the land or is the DP generally spot on? Interesting ... I'd just ask them directly whether they think that level of variation could be plausible for your particular lot. For the land I've had the answer has been a Yes on both occasions. On another note everyone seems to want big standalone houses now so the merits of a granny flat on a small lot might not be there , or it might just be a lot cheaper to do a similar thing with the floorplan but not call it a granny flat. Re: Land Size / Granny Flat / FSR 3Mar 10, 2021 10:29 pm rookie1 Is a granny flat also included in the floor space ratio? Yes they are but if you are in NSW you might want to find out if complying development is an option that is available as that will allow a much higher FSR overriding the council. Re: Land Size / Granny Flat / FSR 4Mar 10, 2021 10:36 pm Hey @Rookie_1 Welcome to the forum Here in WA Council planners have a discretionary allowance for blocks less than 5% code zoning/rezoning Otherwise it's off to WA Planning Authority Check with your Council... put a good spin on it Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Land Size / Granny Flat / FSR 5Mar 11, 2021 5:27 am rookie1 Hi All, New to the forum I'm in the initial stages of really seriously contemplating a knock down re-build. I want to knock down my old fibro house and build a new house and potentially a granny flat as well. I have a few questions and was hoping for some insight/help. My block of land is 13.411 x 33.528 = 449.64 sq meters This is according to the Deposited Plan (DP) document. This is just shy of 450, which is the minimum amount to build a granny flat. Is it worth getting a surveyor to re-assess the size of the land or is the DP generally spot on? Or is there any leeway with it being 0.36 sq meters short of 450 by the council? ----- Is a granny flat also included in the floor space ratio? In my council area, you are only allowed 45% of your land size, so my floor space allowance is 202 sq meters. If the granny flat is included in the total FSR, then I probably scrap the whole granny flat idea as 202 is not much to work with and I will lose quite abit of floor space in the main house. Thanks in advance Hi rookie We really need to know what state you are in as it varies so significantly between states and then council areas. If you cant let people know where you are, you will will find that there are some really smart people on here who can help Cheers Simeon Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Land Size / Granny Flat / FSR 6Mar 11, 2021 3:40 pm Thank you for everyone's replies thus far, much appreciated, all very good points which I will take on board. I am located in NSW and my council is Fairfield Council (postcode 2166). I've been looking at a few floor plans today (from wisdom and clarendon) and since my council only allows me 45% of FSR, i really don't have much to work with, as 202sq meters of total floor space is not that big. So I think I might just completely scrap the granny flat idea (especially if I have to include the floor space from the granny as well), my house will be very small if I had a granny flat. Having said that, even building just a house (without granny), I am finding that 202sq for floor space is just a tad too small. I believe in my council, you must include ground floor + top floor to get your total allowable floor space. Is there anyway to increase the FSR at all? for eg. if you go through a private certifier, is there any flexibility? Or does anyone have any other ways/ideas that this can be achieved? Ideally 250sq for floor space is a perfect size, that would be 55% of my land size. Thanks to all for your expertise and insights Re: Land Size / Granny Flat / FSR 7Mar 11, 2021 4:30 pm rookie1 Thank you for everyone's replies thus far, much appreciated, all very good points which I will take on board. I am located in NSW and my council is Fairfield Council (postcode 2166). I've been looking at a few floor plans today (from wisdom and clarendon) and since my council only allows me 45% of FSR, i really don't have much to work with, as 202sq meters of total floor space is not that big. So I think I might just completely scrap the granny flat idea (especially if I have to include the floor space from the granny as well), my house will be very small if I had a granny flat. Having said that, even building just a house (without granny), I am finding that 202sq for floor space is just a tad too small. I believe in my council, you must include ground floor + top floor to get your total allowable floor space. Is there anyway to increase the FSR at all? for eg. if you go through a private certifier, is there any flexibility? Or does anyone have any other ways/ideas that this can be achieved? Ideally 250sq for floor space is a perfect size, that would be 55% of my land size. Thanks to all for your expertise and insights you really need to talk to an expert ( i can refer you to one) as you get exemptions for things like a garage space, voids, stairs, alfrescos, walls etc so you will find that you can fit more on there. the easiest thing is to get some professional advice Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Land Size / Granny Flat / FSR 8Mar 11, 2021 8:26 pm rookie1 Having said that, even building just a house (without granny), I am finding that 202sq for floor space is just a tad too small. I believe in my council, you must include ground floor + top floor to get your total allowable floor space. Is there anyway to increase the FSR at all? for eg. if you go through a private certifier, is there any flexibility? Or does anyone have any other ways/ideas that this can be achieved? As I mentioned complying development overrides the council control, here's the link for you, this is all basic google-able https://www.legislation.nsw.gov.au/view ... -0572#pt.3 . It says 290m2 so you're in major luck if you are allowed complying dev on your lot. Re: Land Size / Granny Flat / FSR 9Mar 11, 2021 9:26 pm Thanks boris594 I'm excited! That's a glimmer of hope! If I can go through complying development, the 290m2 would be absolutely fantastic! Whats the best way to establish if I'm allowed complying dev on my lot? Is there a process that i can go through? Do I speak to a builder? Or should I just go through the tender process with one of the home builders like wisdom/clarendon and they will find out during the tender process? Thanks again Re: Land Size / Granny Flat / FSR 12May 10, 2021 4:21 pm Hi all, I have a similar question.. I have a lot in Marsden Park, NSW 2765. Its 422 sqm with 12.5 frontages.. can someone guide if its possible to build an attached studio or granny flat within the principal dwelling? Its under Blacktown council. Any pointers would be highly helpful. Thanks, TJ I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4161 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13981 Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and… 0 7279 |
