Browse Forums Building A New House Re: Entry bulkhead design help needed! 6Mar 03, 2021 9:46 am Bcr83 The area where the understairs door in existing design has a 265mm bulkhead if we put a 2340 under stairs door this wont work. I also want the door height for powder, garage, living/study openings to all match etc so cannot reduce understairs door height. Area marked with red – this is a 265d bulkhead running right into the middle of the alcove, this wont work either The kitchen/entry border must have a 265d bulkhead (blue) so this lines up with rest of kitchen bulkhead etc Thoughts are: Yellow areas change to full 120d bulkhead – you will not see different pockets of ceiling other than main entry hallway Understairs door has the full 120mm bulkhead to deal with the 2340 height door (should be ok and should hopefully line up with power/garage/living and study openings?) Blue is 200mm wide 265d bulkhead, allows room for 720w lin10 door (2340) and looks ok from kitchen side Is there a reason you need the bulkheads? Why not remove then from everywhere and that will also make the house more roomy, Also, why are you putting a door under the stairs? There is lots of storage space in your house. You dont really need another store in this big house Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6328 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 11348 G'day I'm trying to put in some privacy screening on my rental rooftop on a tight budget. I've already invested about $500 in the supplies for this. The issue is… 0 32234 |
