Browse Forums Building A New House 1 Feb 21, 2021 2:42 am Just curious about which option will net the highest ROV on a new house. A lot of the driveways in my neighborhood are gravel. This will probably be an investment property, but could be sold if I choose to buy a higher value home. Can I get an opinion on the valuation and not possible saleability as this is variable. So if my house was valued at $350K without a driveway, and I added one of these options. What would the +/- return likely be. If I know I can get dollar for dollar on concrete, I'll go for it. I could do paving myself cheap af, but it's a step up from my patio job. Re: New home - Gravel vs Asphalt vs Concrete vs paving ROV 2Feb 23, 2021 8:29 am It's almost an impossible question to answer as the price a house sells for is infinitely variable. All i can say is, personally if I was buying a house without a concrete driveway i'd be factoring that cost to get one put in. Follow my build here: https://www.instagram.com/ivy5custom Thank you for this! I started drilling the holes (white dots) but I guess I'll just fill them in. So I would glue the abelflex to the footings and then the poured… 2 7820 create a wall cavity/through timber to pass 110 mm sewer pipes. As I understand to pass 110m pipe the frame should be greater than 130-150 mm. 2 12774 |
