Browse Forums Building A New House 1 Feb 13, 2021 8:14 pm Hi everyone, In the process of designing our new build. Our garage will be 6100mm deep x 6500mm wide, we were wondering what the maximum size panel lift door we’d be able to fit across it? We’d like a door to go up to 6000mm if possible, just not sure if there would be enough room on the pillars to run door tracks? A 6000mm door would only leave around 250mm either side of the garage.. Thanks again for this information. If you do hear anything different, would be great to know 4 8256 The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27331 Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 4128 |
