What are the most economical options in connecting NBN, Telephone, TV when doing a new home double story. What should the builder be doing in minimum so that extra stuff can be done after handover.
I am thinking, following configuration
- Terminating NBN in garage (builder does connection from Pit, on basic inclusion)
- data point for each bedroom and terminating in garage
- 3 TV points
- TV antenna and wring
- data point in ceilings to connect WIFI router
- Applicable electrical wiring
Really depends on how much your builder will charge for the work; some may have huge markups whereas others are reasonable ($100-$150 per data run). If you do find it more economical to do it after handover then get the builder to run conduits to all proposed outlet locations.
