Browse Forums Building A New House 1 Feb 03, 2021 10:29 pm Hi home builders I am in the process of house construction in Victoria and attended final walk through recently I realized when the yard was "levelled" there was a significant amount of sand and crushed rock (used during construction) spread across the yard instead of being removed by the builder. Does this not qualify as excess material that the builder should remove before handover? Please assist? Cheers PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10207 Different to what others have said but thanks for that insight. 2 5197 Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 11596 |
