Theatre advice
Im just after ideas for my theatre. Im just wondering what everyone has done with regards to their theatre. We havent put a door on ours but we would still like to block it off when we are in there. Any suggestions?
Thanks everyone
I did acoustic insulation throughout plus acoustic plaster board panels, whether it made a huge different or not I’m unsure. The plasterboard though I can tell is definitely quieter than standard.
1
Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it…
9/05/2023
Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I…
19/05/2023
3
Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished.
