what else am i missing or have i gone too light or too heavy on??
item | units | rate | price | priced from |
Engineering (Slab/Frame) | 1 | 2500 | 2500 | inertia engineering |
Soil Test | 1 | 500 | 500 | inertia engineering |
SUBTOT | 3000 | |||
Concrete Slab | ||||
subgrade (3 x 8hour days) | 24 | 154 | 3696 | guess |
supply (350m x 0.22/m) @ $200/m | 350 | 44 | 15400 | budgy |
plastic | 3 | 107 | 321 | bunnings |
pods | 250 | 16 | 4000 | internet |
mesh (SL102) | 30 | 145 | 4350 | aubry wire industries |
straight bar (N12) | 130 | 8 | 1040 | aubry wire industries |
labour (6men 2 days @$500/m/d) | 12 | 500 | 6000 | statewide |
SUBTOT | 34807 | |||
Floor Finishes | ||||
Epoxy floor to garage (By Us) | 58 | 10 | 580 | bunnings kits |
Polished concrete | 172 | 115 | 19780 | ozgrind range 90 to 120 |
Carpet | 101 | 70 | 7070 | internet rate |
External Tiling (By Us) | 59 | 70 | 4130 | 50 tile 10 glues, self labour |
SUBTOT | 31560 | |||
FAĆADE | ||||
lay rendered block per spm | 240 | 88 | 21120 | nick harman |
render brickwork | 240 | 40 | 9600 | internet rate |
external paint | 240 | 10 | 2400 | internet rate |
SUBTOT | 33120 | |||
Hydraulics | ||||
plumbing inground | ||||
Tanks (12,000L QTNK) | 2 | 1695 | 3390 | qtanks |
Filter (UV 105L/m) | 1 | 3000 | 3000 | internet rate |
Pump | 1 | 900 | 900 | internet rate |
SUBTOT | 7290 | |||
Roof Sheeting | 400 | 80 | 32000 | internet rate |
Fire report and works | 350 | 18 | 6300 | stroud (18/m2) |
SUBTOT | 38300 | |||
Internal Linings | ||||
Wall linings | 701 | 20 | 14020 | internet rate |
Wall Painting Internal | 701 | 10 | 7010 | internet rate |
SUBTOT | 21030 | |||
joinery | 1 | 30000 | 30000 | stab in the dark |
sinks/taps/basins/baths/towel | ||||
SUBTOT | 30000 | |||
doors | ||||
roller shutter supply only | 1 | 4000 | 4000 | ebay |
main front | 1 | 859 | 859 | bunnings Corinthian Doors 1200 x 2040 x 40mm Blonde Oak AWOWS 5VG Clear Glass Entrance Door |
unit front | 1 | 812 | 812 | bunnings Corinthian Doors 1020 x 2040 x 40mm Blonde Oak AWOWS 5VG Clear Glass Entrance Door |
single cavity | 2 | 380 | 760 | 180 frame per leaf incl hardware |
double cavity | 1 | 760 | 760 | bunnings |
internal hollow | 10 | 198 | 1980 | humes HAM1 |
internal solid | 5 | 198 | 990 | humes HAM1 |
internal door handles | 15 | 40 | 600 | Lockwood 63mm black velocity L3 |
hinges | 23 | 10 | 230 | pinnacle 100mm fixed butt black 2 packs |
front door hardware | 2 | 400 | 800 | bunnings |
SUBTOT | 11791 | |||
electrical | ||||
dbl gpo (supply) | 44 | 7.15 | 314.6 | clipsal iconic d-gpo sparky direct |
light switch (Supply) | 30 | 9.9 | 297 | clipsal icopnic assumed double sparky direct |
cable | 4 | 126.5 | 506 | 2.5mm 100m drum sparky direct |
downlights (supply) | 80 | 16 | 1280 | clipsal TPDL1C2 9w tri colour dimmable led downlight sparky direct |
fans (supply) | 8 | 365 | 2920 | DC fans beacon lighting |
IXL (main & flat) supply | 2 | 219 | 438 | IXL Tastic Silhouette 3 In 1 Bathroom Heat Fan Light |
main board termination | 0 | ?? | ||
3 phase feed from boundary | 0 | ?? | ||
fees/connections | 0 | ?? | ||
solar (8kW) | 1 | 8000 | 8000 | our system was 1000/kw |
external d-gpo | 5 | 24.14 | 120.7 | sparky direct |
SUBTOT | 13876.3 | |||
glazing hxw | ||||
2100x610 awning | 8 | 372 | 2976 | onlinewindows.com.au |
1200x610 awning | 2 | 266.51 | 533.02 | onlinewindows.com.au |
1754x600 louvre | 2 | 557.82 | 1115.64 | onlinewindows.com.au |
600x1810 fixed | 4 | 222.64 | 890.56 | onlinewindows.com.au |
1200x1510 slide | 2 | 328.32 | 656.64 | onlinewindows.com.au |
2100x3610 slide door | 1 | 1610 | 1610 | onlinewindows.com.au |
2100x1810 slide door | 4 | 751 | 3004 | onlinewindows.com.au |
SUBTOT | 10785.86 | |||
landscape | 1 | 25000 | 25000 | guess |
asphalt driveway | 1 | 25000 | 25000 | Allroads |
pool | 1 | 50000 | 50000 | budget |
Land | 450000 | offer | ||
Stamp Duty | 15000 | online calced | ||
TOTAL BUILD | 800560.2 |
