Browse Forums Building A New House Re: Zero alottment boundary garage 2Jan 05, 2021 6:51 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Zero alottment boundary garage 3Jan 05, 2021 10:54 pm chippy You won't need to do any retaining along your zero lot garage as they are installing a dropped footing to allow for that. The lack of eaves isn't an issue, it's done all the time. You don't need to fence along the garage as the garage wall is on the boundary line. The fence will run up to the garage and stop then start again in front of the garage if you want a front fence between the two properties. It sounds like you will need retaining to other areas of the block and that will be your responsibility. Thanks for the advice, appreciated thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16180 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17113 In WA zero lot is actually zero lot. We build 10mm in from the boundary. My house and my neighbours house have garages that sit only 20mm apart. When I had our roof done… 3 7021 |
