Browse Forums Building A New House 1 Dec 09, 2020 7:58 pm Hi Guys, Just wanted some advise on the best way to repair this render? Its hebel and rendered built by Carlisle Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I was thinking of using Dulux Medium Texture and jus tint it with the color as per color scheme from Carlisle https://www.bunnings.com.au/dulux-4l-me ... t_p1409809 I'll just fill it up until its flushed. will it work? Thanks Re: Repair a Hebel Render 2Dec 09, 2020 8:26 pm It is almost impossible to patch texture coat and not have it noticeable. To do it properly you redo the whole wall. The wall will be coated in acrylic texture coat that is applied by trowel. The paint in your link isn't the same. To effect a proper repair it needs to be flushed with a sand and cement filler and then texture coated over the top. Do you care how obvious it is? Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Repair a Hebel Render 3Dec 10, 2020 7:31 am chippy Do you care how obvious it is? No... not really especially if I need to redo the whole wall. this is a rental property so looks ,,, it does not matter much. I just wanted it flushed... and close color as much as possible. I was looking at different options for a fence for my build and Hebel PowerFence seemed like a good option (one of the criteria was a solid wall look). However, I don't… 0 5905 1 6637 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6207 |
