Browse Forums Building A New House 1 Dec 07, 2020 9:14 am Dears, here is a picture of misaligned bricks at the base of the brick wall. While it can be used as an example of how not to do Mortar and chipped bricks etc, my major question is about the misalignment of bricks at the base. Any thoughts! Will this be a Structural Problem. if yes, what is the extent of this Problem? Serious? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thnx. Re: Structural problem or not 2Dec 07, 2020 10:01 am nfaisal Dears, here is a picture of misaligned bricks at the base of the brick wall. While it can be used as an example of how not to do Mortar and chipped bricks etc, my major question is about the misalignment of bricks at the base. Any thoughts! Will this be a Structural Problem. if yes, what is the extent of this Problem? Serious? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thnx. Post some more photos that give a perspective, some from a distance that show good part of the wall Re: Structural problem or not 3Dec 08, 2020 6:20 pm IamSAM nfaisal Dears, here is a picture of misaligned bricks at the base of the brick wall. While it can be used as an example of how not to do Mortar and chipped bricks etc, my major question is about the misalignment of bricks at the base. Any thoughts! Will this be a Structural Problem. if yes, what is the extent of this Problem? Serious? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thnx. Post some more photos that give a perspective, some from a distance that show good part of the wall Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ here is a picture of full wall Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 31852 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 46973 |
