Browse Forums Building A New House Re: Termite protection - Pine treated sleepers 3Nov 26, 2020 8:34 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Termite protection - Pine treated sleepers 5Jun 08, 2021 8:49 pm building-expert You most likely have interfered with termite management system and voided your warranty. Termites can breach or avoid barriers. Get Flick back to re treat I m in a similar position but not due to garden beds but a irresponsible concreter laying concreting without keeping 50mm gap below weep holes as specified by Rentokil. He has compromised the gap at 3 places. Does the warranty void immediately without giving us opportunity to rectify ? Can the concrete in that area be removed considering it’s only few days old? Re: Termite protection - Pine treated sleepers 6Aug 15, 2021 11:42 am Kas83, How did your Rentokill inspection go? did you have to remove the concrete? We did a path around around our house as recommended by the builder, we obviously wanted it all the same height and then realised on the garage wall the weep holes and termite barriers are lower and have been covered over about a 4 meter distance. The weep holes and termite barriers are lower than the driveway surface in this area so we essentially need that whole side much lower than the rest of the yard just to keep the weep holes and termite barriers clear, we would end up with a mote in those areas. Yes, neither is termite damage that is not covered by your house insurance. 3 6592 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6592 I’m just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52859 |
