Browse Forums Building A New House 1 Nov 18, 2020 11:09 pm We upgraded our insulation to R2.5 but when we visit the site, we saw Bradford R2.0 packaging on the bin. We can't see our insulation now as the plaster has been installed. We ask our builder about this and replied saying it's not their rubbish but from the other builder in the neighboring site. It's a good excuse but my question is, is it possible to falsify insulation certificate? Is it possible that they just missed our upgrade and later on issue a certificate saying R2.5 even if only R2.0 was actually installed? Re: Can you falsify insulation certificate? 2Nov 18, 2020 11:15 pm If its a supply and install from Bradford's they supply a warranty certificate with what has been installed. I would suggest once you have received that certificate is ring Bradford and say you have misplaced you warranty certificate and can you resend direct to you, you will know then if there has been any discrepancies between the 2 Re: Can you falsify insulation certificate? 3Nov 18, 2020 11:27 pm Doozer1905 If its a supply and install from Bradford's they supply a warranty certificate with what has been installed. I would suggest once you have received that certificate is ring Bradford and say you have misplaced you warranty certificate and can you resend direct to you, you will know then if there has been any discrepancies between the 2 Thank you! After our builder talked us out of a private inspector for our pre-plaster and after seeing the wrong packaging, we kinda have doubts now. We regret not insisting on getting pre-plaster inspected. Re: Can you falsify insulation certificate? 4Nov 19, 2020 7:55 am Lil.home.14 our builder talked us out of a private inspector for our pre-plaster Very loud alarm bells ringing there. Pre plaster is a very important inspection. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Can you falsify insulation certificate? 5Nov 19, 2020 9:16 am Lil.home.14 Doozer1905 If its a supply and install from Bradford's they supply a warranty certificate with what has been installed. I would suggest once you have received that certificate is ring Bradford and say you have misplaced you warranty certificate and can you resend direct to you, you will know then if there has been any discrepancies between the 2 Thank you! After our builder talked us out of a private inspector for our pre-plaster and after seeing the wrong packaging, we kinda have doubts now. We regret not insisting on getting pre-plaster inspected. Ask yourself why they talked you out of getting that inspection done and don't let them talk you out of any future inspections. Re: Can you falsify insulation certificate? 6Nov 19, 2020 7:07 pm Lil.home.14 Thank you! After our builder talked us out of a private inspector for our pre-plaster and after seeing the wrong packaging, we kinda have doubts now. We regret not insisting on getting pre-plaster inspected. Yeah, I think it's critical to get independent inspections done at important stages of the build. I wouldn't be relying on the builder's integrity for the biggest purchase you'll probably make in your lifetime. I honestly hope your builder has some the right thing, & best of luck with this & the remainder of the build. Re: Can you falsify insulation certificate? 7Nov 20, 2020 7:10 am Lil.home.14 We upgraded our insulation to R2.5 but when we visit the site, we saw Bradford R2.0 packaging on the bin. We can't see our insulation now as the plaster has been installed. We ask our builder about this and replied saying it's not their rubbish but from the other builder in the neighboring site. It's a good excuse but my question is, is it possible to falsify insulation certificate? Is it possible that they just missed our upgrade and later on issue a certificate saying R2.5 even if only R2.0 was actually installed? the honest answer is yes its possible. Whilst the packaging is from Bradford no doubt they could have used a subcontractor. Hopefully they havent falsified the certificate but its definitely possible Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Not unless you have managed to put it as a special condition into the contract somehow. 1 6155 We are in NSW and require 2 positive covenants to be placed on the property didnt really underdtand this but apparently it will take a few months, and have just been… 2 7473 For anyone that comes across this issue in the future - Just did what aussieta said and found a plumber to inspect it and sign off on it. Was difficult to find someone to… 3 7036 |
