Browse Forums Building A New House 1 Nov 08, 2020 10:21 am Are there any project builders in Sydney that can build to a higher spec? I want a piered raft slab, double brick throughout, suspended slab first floor, excavated basement carpark etc but I don't need a fully custom floorplan / architecturally designed features etc and am happy to adapt a standard design. So in terms of what I need, I'm sort of in between a project builder and a custom builder. Are there any project builders that can work with higher spec builds like what I've described above? in Sydney? Thanks Re: High spec project builders in Sydney? 2Nov 08, 2020 12:56 pm echelon6 Are there any project builders in Sydney that can build to a higher spec? I want a piered raft slab, double brick throughout, suspended slab first floor, excavated basement carpark etc but I don't need a fully custom floorplan / architecturally designed features etc and am happy to adapt a standard design. So in terms of what I need, I'm sort of in between a project builder and a custom builder. Are there any project builders that can work with higher spec builds like what I've described above? in Sydney? Thanks Hi Echeclon6 We formed our company to operate exactly in that space. Depends on your budget, but we are doing mid to high specification homes that don't need any upgrades from $650-900k. if your interested check out www.ashingtonhomes.com.au cheers Simeon Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: High spec project builders in Sydney? 4Nov 09, 2020 4:58 am Lemans Check out future flip on instagram/website. just looked up and followed. thanks for the tip Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: High spec project builders in Sydney? 6Nov 09, 2020 2:20 pm SejaeD Lemans Check out future flip on instagram/website. just looked up and followed. thanks for the tip Re: High spec project builders in Sydney? 7Nov 09, 2020 5:57 pm Underground basement/garage: excavate/remove soil, pour footings and slab and then install and pour Dincel walls over (will be much faster than brick walls). You can also add some Radmix to the concrete while pouring to protect Dincel walls from water ingress even further and to save on waterproofing (which is even not a requirement for Dincel). Fairly simple job but costly job considering that the main expenses will be coming in from the excavation and removal of soil part. So this already won't be a standard design. Instead of fully suspended slab, you might also consider Bondek or Speedfloor, they will be much faster to install and much cheaper too. Double brick might not be the best option for Sydney, especially if we are talking about highly reactive soils. This will be very heavy house (esp. if you are considering tiled roof) which would require deep/heavy and labour intensive footings. Considering underground basement works, think of $100k+ on site costs alone. Also, as per BASIX, double brick might not be providing a lot of advantages thermally due to fairly limited insulation capabilities but having a lot of "unnecessary" thermal mass which would have to be heated or cooled down during cold or hot weather streaks which Sydney is quite known of. You would certainly require custom design and custom house builder for that. Re: High spec project builders in Sydney? 8Nov 09, 2020 8:15 pm alexp79 Underground basement/garage: excavate/remove soil, pour footings and slab and then install and pour Dincel walls over (will be much faster than brick walls). You can also add some Radmix to the concrete while pouring to protect Dincel walls from water ingress even further and to save on waterproofing (which is even not a requirement for Dincel). Fairly simple job but costly job considering that the main expenses will be coming in from the excavation and removal of soil part. So this already won't be a standard design. Instead of fully suspended slab, you might also consider Bondek or Speedfloor, they will be much faster to install and much cheaper too. Double brick might not be the best option for Sydney, especially if we are talking about highly reactive soils. This will be very heavy house (esp. if you are considering tiled roof) which would require deep/heavy and labour intensive footings. Considering underground basement works, think of $100k+ on site costs alone. Also, as per BASIX, double brick might not be providing a lot of advantages thermally due to fairly limited insulation capabilities but having a lot of "unnecessary" thermal mass which would have to be heated or cooled down during cold or hot weather streaks which Sydney is quite known of. You would certainly require custom design and custom house builder for that. Interesting... thanks. So if I don't go with the basement garage, are there any project builders that can do double brick / suspended slab? Re: High spec project builders in Sydney? 9Nov 09, 2020 11:40 pm echelon6 Interesting... thanks. So if I don't go with the basement garage, are there any project builders that can do double brick / suspended slab? I am not aware of anyone. This is not their bread and butter, so I doubt there is any. Re: High spec project builders in Sydney? 10Nov 10, 2020 4:10 am Manhattan52 \"SejaeD":hacsm6oo \"echelon6":hacsm6oo Are there any project builders in Sydney that can build to a higher spec? I want a piered raft slab, double brick throughout, suspended slab first floor, excavated basement carpark etc but I don't need a fully custom floorplan / architecturally designed features etc and am happy to adapt a standard design. So in terms of what I need, I'm sort of in between a project builder and a custom builder. Are there any project builders that can work with higher spec builds like what I've described above? in Sydney? Thanks[/quote:hacsm6oo] Hi Echeclon6 We formed our company to operate exactly in that space. Depends on your budget, but we are doing mid to high specification homes that don't need any upgrades from $650-900k. if your interested check out http://www.ashingtonhomes.com.au cheers Simeon[/quote:hacsm6oo] Just stumbled across this SejaeD.... definitely up my alley and will be giving you a call... hard to find the right site though at the moment $$ wise Hi Manhattan I know what you mean. I am trying to buy something in your old stomping ground and the market is crazy. Have my eye on one at the moment that I want to set up as a Display, but we will see how we go at auction. Congrats on yours by the way! so happy for you cheers Simeon Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: High spec project builders in Sydney? 11Nov 10, 2020 6:11 am echelon6 Seems an unusual approach-why not instead find projects in the local area which share features with your proposed and try to talk to the owners about quality, delivery, cost etc etc (apologies if you have already done this. You run the risk of getting a project builder who is prepared to 'have a go' but loose out on local experience, practices and all the rest. Just curious-is it ground conditions or something else which warrants piers and a suspended basement slab? In Lower North Shore? Damn. Re: High spec project builders in Sydney? 12Nov 10, 2020 8:24 am worldofmud @echelon6 Seems an unusual approach-why not instead find projects in the local area which share features with your proposed and try to talk to the owners about quality, delivery, cost etc etc (apologies if you have already done this. You run the risk of getting a project builder who is prepared to 'have a go' but loose out on local experience, practices and all the rest. Just curious-is it ground conditions or something else which warrants piers and a suspended basement slab? In Lower North Shore? Damn. It's just preference. And the extra piers to ensure less chance of cracks in future. Re: High spec project builders in Sydney? 13Nov 10, 2020 9:31 am Do you know the ground conditions at basement excavation level and are you expecting clay soils? Hi all, We are looking to build a new two storey house in western Sydney. Can anyone recommend a smallish builder to go with? We are trying to stay away from the big… 0 12140 Thanks again Simeon for being so elaborate. Appreciate it. Its gives us a very idea. Kind Regards 4 3666 It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8267 |
