Browse Forums Building A New House 1 Nov 04, 2020 6:22 pm Hi, I'm currently going through the design process for a metricon build and cannot find a way to have a laundry chute set up. I'll be willing to make some small additions to the plan on the top floor to accommodate. Any help would be greatly appreciated! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: How can I make a laundry chute work here?? 2Nov 07, 2020 10:28 pm It looks like WIR2 and WIL are above the laundry so I'd be considering one of those to locate the top of the chute. Have you got a fixed location in the laundry for where the bottom of the chute will be? Re: How can I make a laundry chute work here?? 3Nov 08, 2020 6:23 am Thanks for the reply, yes you are right with WIL and WIR2. The left side of the laundry as per the plan will run a stone bench top and appliances. the right side wall will have a series of floor-to-ceiling cabinets. it was more whether I could consider using an angled chute or have it accessible by the hallway rather than a particular room however the walk-in linen would be a reasonable area for chute?? Re: How can I make a laundry chute work here?? 4Nov 08, 2020 10:44 am I don't think you will be able to fit a laundry chute. Your laundry is directly below bedroom 2. Your WIL, which would be the most obvious spot to put a chute and even the robe in bedroom 2 are above the kitchen. Unfortunately I'd say you are out of luck with regards a laundry chute. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: How can I make a laundry chute work here?? 5Nov 08, 2020 6:24 pm chippy I don't think you will be able to fit a laundry chute. Your laundry is directly below bedroom 2. Your WIL, which would be the most obvious spot to put a chute and even the robe in bedroom 2 are above the kitchen. Unfortunately I'd say you are out of luck with regards a laundry chute. Yes was hoping this wasnt the case.. I would say if there was any chance it would have to be accessed by the master bedroom bed one but that's not ideal. Do you think that possible from there? Re: How can I make a laundry chute work here?? 6Nov 08, 2020 8:59 pm The bed 1 WIR sits over the rumpus and doesn't get close enough to run a chute to the laundry. Unfortunately the laundry sits directly below bed 2. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10098 Not sure who you're building with, but I moved in recently to a 11month scheduled, 8 month actual build on the South coast/Illawarra NSW 3 5911 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61375 |
