Browse Forums Building A New House 1 Oct 30, 2020 9:29 am I am planning to knock down and rebuild, but not sure which builder should I choose. I read some positive and negative comments between those builder. so really unsure now what to do =(
Can somebody please share their experience. Thank you Re: Rawson or Wisdom Homes - Sydney Area 2Oct 30, 2020 12:15 pm ![]() I am planning to knock down and rebuild, but not sure which builder should I choose. I read some positive and negative comments between those builder. so really unsure now what to do =( Can somebody please share their experience. Thank you Good choice between these two builders. I know the management of both and they are all nice people for what that is worth. I personally think Wisdom are building some really nice homes at the moment. One just sold for over $5m here in Sydney. From all reports they are both a bit slow with the planning phase but especially Wisdom the build process goes very fast. Therefore if it had to be between the 2 of them I would probably give the edge to Wisdom, The GM Mark Scully comes on here regularly to answer questions which is quite refreshing Good luck with your decision cheers Simeon Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Week 32 & 33 Construction The pace has really picked up, lot's of good progress being made... Lower brick clean… 51 21914 Hi guys, We are planning to buy a land in Box Hill and build this design with Rawson homes - ??https://www.rawsonhomes.com.au/home-designs/corrima?? I tried to search on… 0 589 I built the Ambassador 36 as well and it's in the construction plan. Is it those green steel beams or meant to be in addition to them? 2 1322 |
