Browse Forums Building A New House 1 Oct 24, 2020 4:46 pm Hi all, would there be any cost saving to raise the elevation of my first floor level by just increase the thickness between ground floor ceiling and first floor level, rather than increase the ground floor ceiling height? My reason is simply because I would only want my first floor sit at a higher level for better ocean view, while the ground floor are bedrooms and laundry don't require ceiling higher than 2400mm. I understand the associated cost to increase 2400 to 3000mm will be significant. G/F area is near 140m2. I know this could be answered from my builder, but just wondering if anyone here has been in similar situation during your planning stages? Cheers isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17608 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 47014 |
