Browse Forums Building A New House 1 Oct 21, 2020 3:25 pm Hi all, We have been quoted by our builder to connect our block to the main power board. Our block is on a strata of 9 lots, and has the conduit in place but not the cable. We have been quoted $5,197 to run underground single phase power up to 100m. We are approximately 90m from the main switch board. That seems like a lot to me, and I question where they pulled this number from. Are there any experts in this field that might know if this is an about accurate quote for 100m of single phase power run? Thank you Re: Quote for connecting our block to power 2Oct 21, 2020 5:35 pm I had about the same distance to cover from my post (but 3 phase) My quotation included: Install three phase aerial service cable. Extend existing conduits. Install three phase 40Amp underground consumer mains. Install meter box and wiring to main switch. Install double power point in meter box for builders supply. Install temporary earthing. and was $7900 in total inc. GST Another 2 quotations were even higher. But this is in Sydney, which is generally 30% higher than WA. Re: Quote for connecting our block to power 3Oct 23, 2020 8:19 am Thats actually quiet cheap for Approx. 90 meters, I would suss out what size cable they are using, should probably be 35mm with a distance that long "Losers" "humanity" "off time" "your" "top notch" "love symbol" Sounds like ponzo is done using other people's toilets 36 23738 hey there! π so, itβs kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20857 I was being kind to the builder. With the amount charged for the upgrade the builder is probably charging closer to 100% margin. There are a few variables as I… 5 14299 |
