Browse Forums Building A New House Re: Room size 4Oct 21, 2020 8:36 am Hi guys, Thank you for the idea. I have already tried it. The problem for me occurs, not really when I have visualize 1 room (approximately). It happens when I have to visualize all the rooms together and imagine how big the plan will be, or how small it should be, or even that how small or big it will look if there is a + or - of few meters.. Please help. Thank you, Re: Room size 5Oct 24, 2020 7:44 am ![]() Hi guys, Thank you for the idea. I have already tried it. The problem for me occurs, not really when I have visualize 1 room (approximately). It happens when I have to visualize all the rooms together and imagine how big the plan will be, or how small it should be, or even that how small or big it will look if there is a + or - of few meters.. Please help. Thank you, post your plan showing approx dimensions and direction of north and i can draw up a rough plan that can show the size of the whole house and individual rooms and then make adjustments to increase or reduce Re: Room size 6Oct 24, 2020 8:13 am https://onetoonedisplays.com.au/offer/ Walk through your home in real life scale before you build. Just an idea. If you are allowed to change the plan at all, if you make a couple of small alterations to the robes in Bed 2 and Bed 4, you can create a whole heap of extra room. 9 1840 ![]() Similar to the size yard we are going to end up with after we build (about 11 deep by 12.5 wide). In the suburb we're building this would be considered way above… 2 1279 Hi Lockmac, Your return air grille should always bigger than the return air duct itself, this is because the return air filter restricts the airflow & as it gets dirty it… 0 4634 |
