Browse Forums Building A New House 1 Oct 17, 2020 11:20 am In this picture above, you can see our neighbour's house on the left and our vacant property (right) which should start construction soon.
Is the entirety of the fence encroaching in our land? My understanding was that it would be the width of the fence would be split across both properties - my neighbours and mine. I also assumed the fencing would be more flush against the garage wall of the neighbour, so that the yellow arrow gap would not exist. Our garage is not being built against the neighbour's garage, it is on the other side like this: The red 'circled' portion is what I am showing in the picture above. I will admit, I live in Melbourne and have not had the chance to visit the property yet. I also don't know much about fencing/building etc. So I am trying to educate myself with my first post here....so please be nice In summary - just trying to understand if the fencing has been erected correctly. Thank you for any insights/advice! Re: Is the fence that has been recently put up correct? 3Oct 19, 2020 10:45 am That looks right. When you build to boundary, the wall is usually around 15-20cm inside the boundary to allow for the guttering to remain within the property. The fence posts should form the boundary between the 2 blocks. Re: Is the fence that has been recently put up correct? 4Oct 19, 2020 12:47 pm looks right! When the they build a zero boundry lot there is always around 180mm or 200mm gap. The little post (Yellow Arrow) should come out this much as that is to the actual boundry! Hope that helps Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72335 Iām loving the potential versatility and practicality of a bench seat in a shower. Anyone had one of these done recently? Not sure if they are straight forward and easy… 0 762 You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18063 |
