Browse Forums Building A New House 1 Oct 13, 2020 12:55 pm Hi, there, Our home has finished the framing stage, and today I was told by our SS that they need to add a section of wall in the blue area to create a box in order to be able to run air-con down to the back family room because there is a steel beam in joist space that is indicated by the red line, thus anything towards the front of the house from there can't gain access into the rear room downstairs. It is odd to me that this isn't found in the original design and needs to be picked up by our SS in the construction stage. Does anyone know if this is appropriate to do? Also, what could be the reason that it's only found in this late stage? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Adding an aircon zone in construction stage 2Oct 13, 2020 1:15 pm It’s funny that they’ve allowed for 5 air con voids but haven’t actually looked at where the beams go...just laziness I guess. If you have to go ahead, make sure you negotiate a matching return on the other side, so it looks a little more integrated. They may argue but stand your ground its their mistake. Your other option would be to have a bulkhead downstairs not sure whether that would work? The fastest thing a builder will do is bank your cheque, those systems work perfectly with lightning speed, everything else is slow burn. Just the way it is. 1 8706 Yes it had a house on it. But Melbourne water only wanted something the original size of the existing house. We managed to fit a 45sq house on. 10 33666 Hi All It has been a few weeks since my last update. The build has been progressing well. No major issues to report. The scaffolding was dropped today, gyprock will be… 96 356960 |
