Browse Forums Building A New House 1 Oct 09, 2020 9:03 pm Hi guys, does anyone out there use hebel floor in their new build? Just wondering how much height needs to be factored in for support and timber to allow for running aircon ducts etc while using hebel floor. . Would anyone who has it installed this product as a flooring system be able to confirm how many mm needs to be factored on to overall heights. Floor system is 75mm for hebel, just after a total mm measurement that would be safe to go with. Thanks Re: Hebel floor height provisions 2Oct 09, 2020 10:47 pm Hi Kinigo, Normally 300mm I joists with 75mm Hebel ontop making it 375mm overall. Some will go 240mm but you then have to drop ceilings for plumbing under the I joists Would also like an opinion from anyone that has used xcem over hebel for floors. Thanks 1 14345 I was looking at different options for a fence for my build and Hebel PowerFence seemed like a good option (one of the criteria was a solid wall look). However, I don't… 0 5938 1 6697 |
