Browse Forums Building A New House Re: New build - south facing windows 3Apr 23, 2021 4:35 pm Hi Camel. I suggest installing a slit window, a tall and narrow window, maybe two if you can, into the ground floor family west wall with a shading device over, possible an awning you can remove during winter or deciduous plants and reducing both south facing windows as far as you are comfortable with.If you cant install an awning or plants then no biggie. Just have blinds or curtains for the summer time and offset it with AC if need be. Two slit windows, side by side in the GF and matched in the FF would help and look nice. Those south facing windows will loose a lot of heat from your main living areas on both GF and FF. I strongly suggest making them smaller. Its basically a chimney sucking out your heat. Can you add a window into the west retreat wall? The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18203 It might be a bit darker in the mornings but the light is still light, so you should be getting it. Similar to what you see from your western windows 3 19991 Well these guys are not looking good... I sent them a written enquiry last week and they have not yet replied. If they cannot respond to a simple… 4 10632 |
