Browse Forums Building A New House 1 Oct 08, 2020 1:35 pm hi, Hope you can provide me some guidance. Due to Clipsal hectic prices we went for a batton lights in the bathroom, laundry and passage adjoining bedroom wing. I believe the batton just comes with a single bulb and no fitting over it. What is the budget friendly but a modern way of finishing the look of that specific area, dont think a pendant will work in bathroom, pls correct me if i am wrong. Do you have any pics to help. Display homes are so fancy and have expensive fittings so that wouldnt be me any indication Re: Ideas for light fittings 2Oct 08, 2020 7:43 pm Hi We did the same thing and opted for batten fix in bedrooms and wet areas. I have found if you Goggle DIY Batten Fix many light fittings can be found that screw directly into the batten holder and are very affordably. A few options are linked below https://onlinelighting.com.au/interior/ ... n-fix-diy/ https://www.beaconlighting.com.au/light ... batten-fix https://www.micalighting.com.au/lightin ... d-i-y.html Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11713 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17380 It might be a bit darker in the mornings but the light is still light, so you should be getting it. Similar to what you see from your western windows 3 19992 |
