Browse Forums Building A New House 1 Oct 06, 2020 1:15 pm Hey guys, I have a house plan that has a void in the family room space along the wall side as you can see in the image below. I want to build a fireplace and tv unit joinery along that wall, so it's a seamless look against the wall. However a lot of the fireplace designs I've seen usually have the fireplace feature wall go right up to the bulkhead or ceiling, however with a void space it would need to up to the ceiling of first floor which would probably be both very expensive and not really achievable. The house design will be contemporary so not really looking to make a traditional looking fireplace with a mantle, which would be one option. I attached some inspo of the look I'd like to achieve. Has anyone done something like this or have any ideas for the fireplace joinery here? PlansLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ InspoLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Fireplace and TV joinery in a family room with a void? 2Oct 06, 2020 2:52 pm ![]() Hey guys, I have a house plan that has a void in the family room space along the wall side as you can see in the image below. I want to build a fireplace and tv unit joinery along that wall, so it's a seamless look against the wall. However a lot of the fireplace designs I've seen usually have the fireplace feature wall go right up to the bulkhead or ceiling, however with a void space it would need to up to the ceiling of first floor which would probably be both very expensive and not really achievable. The house design will be contemporary so not really looking to make a traditional looking fireplace with a mantle, which would be one option. I attached some inspo of the look I'd like to achieve. Has anyone done something like this or have any ideas for the fireplace joinery here? PlansLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ InspoLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ if the fireplace is meant for heating as the void will make all the heat rise up to the upstairs rooms and the family room will be cold...but why can't the chimney stop at downstairs ceiling height (as in your photo) and the flue can exhaust out through the wall Re: Fireplace and TV joinery in a family room with a void? 4Oct 06, 2020 3:45 pm ![]() ![]() Hey guys, I have a house plan that has a void in the family room space along the wall side as you can see in the image below. I want to build a fireplace and tv unit joinery along that wall, so it's a seamless look against the wall. However a lot of the fireplace designs I've seen usually have the fireplace feature wall go right up to the bulkhead or ceiling, however with a void space it would need to up to the ceiling of first floor which would probably be both very expensive and not really achievable. The house design will be contemporary so not really looking to make a traditional looking fireplace with a mantle, which would be one option. I attached some inspo of the look I'd like to achieve. Has anyone done something like this or have any ideas for the fireplace joinery here? PlansLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ InspoLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ if the fireplace is meant for heating as the void will make all the heat rise up to the upstairs rooms and the family room will be cold...but why can't the chimney stop at downstairs ceiling height (as in your photo) and the flue can exhaust out through the wall Hi thanks for replying, do you mean just do the same as in the photo and end the chimney height at the downstairs ceiling height with a flat top? I wonder if that might look odd from the 1st floor as you can see down into the family room. Maybe not but i can’t visualise it.. Re: Fireplace and TV joinery in a family room with a void? 5Oct 08, 2020 3:08 pm Nice! Is that like a cube along the wall for the chimney flue and fully open fireplace below? Re: Fireplace and TV joinery in a family room with a void? 7Oct 18, 2020 5:03 pm ![]() Personally I would just take the chimney all the way up to 2nd floor. It would look good in the void and draw the attention of viewers to that massive fireplace. Costs shouldn’t be too huge given it is only timber and drywall. Re: Fireplace and TV joinery in a family room with a void? 8Oct 19, 2020 7:35 pm ![]() ![]() Personally I would just take the chimney all the way up to 2nd floor. It would look good in the void and draw the attention of viewers to that massive fireplace. Costs shouldn’t be too huge given it is only timber and drywall. Maybe I'm overthinking it and the simple answer is as you described, just take it to the top floor. Thanks! yes i agree with socangal .black table will be excellent for this room 2 10719 We are putting a track light in a wall batten that is positioned just under the balustrade on the wall of the void. The track will have 4 spotlights that can be adjusted… 2 1090 |
