Browse Forums Building A New House Re: Large windows in Void facing west 5Sep 25, 2020 5:09 am Splashers I have the same situation in my home and I dont find it a problem. We have put in Comfort Glass which does help a bit, we have 600mm eaves and we also have motorised blind as well. Winter it is absolutely gorgeous in this space but in summer we have maybe closed the blinds a hand full of times. Personally I open the house up with breezes as much as possible than run air con anyway Thanks for letting me know, could you tell me what size windows you have though in that space? I will have solar so can run air con pretty much all the time but just not sure. In my parents home we found that the west facing living room was always 2 degrees warmer than any other room...even with the aircon on. It might be a bit darker in the mornings but the light is still light, so you should be getting it. Similar to what you see from your western windows 3 19987 Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2553 To me, that's what it looks like: poor backfilling and/or compaction. The width is about 1000mm maybe. That conduit in the photo is for the NBN. The water is about… 4 8039 |
