Browse Forums Building A New House 1 Sep 22, 2020 3:35 pm Can anyone help me understand if this seems reasonable or not. We are in the process of planning our build and we requested for a partition shower screen instead of the normal screen/door for our ensuite shower. The quote we got back from our builder was $3,400. Shower area is 1800x900 so I would assume a partition screen would be around 2m high x 1m wide which in my experience should cost between $700 - $900 installed. Add a few dollars for markup and the drain and i can't see how we get anywhere near that price. However, when we queried the price the answer back was that the shower floor needs to be recessed to create a grading for the strip drain (plus the price for the drain itself). So is this a reasonable requirement (i dont know much about how a bathroom would normally be built)? Follow my build here: https://www.instagram.com/ivy5custom Re: Quote for partition shower screen - is it unreasonable? 2Sep 24, 2020 9:58 am The shower alcove in our main bathroom is 2400mmx1000mm. Unsure if it’s the same as you call a partition wall, but we have what our builder describes as nib walls at either end of the shower alcove, with a wide glass door and a narrow fixed glass panel in between. Each nib wall (2700mmx600mm) cost $210 which included full height wall tiling on the shower side. We also have a 900mm strip drain at one end of the shower, the tiled floor is sloped to allow all water to flow into that drain. The drain was an additional $400. Total cost $810. Re: Quote for partition shower screen - is it unreasonable? 3Sep 24, 2020 10:27 am Bebbsy The shower alcove in our main bathroom is 2400mmx1000mm. Unsure if it’s the same as you call a partition wall, but we have what our builder describes as nib walls at either end of the shower alcove, with a wide glass door and a narrow fixed glass panel in between. Each nib wall (2700mmx600mm) cost $210 which included full height wall tiling on the shower side. We also have a 900mm strip drain at one end of the shower, the tiled floor is sloped to allow all water to flow into that drain. The drain was an additional $400. Total cost $810. Not quite the same, we won't have the nib walls but the floor and strip drain would have been basically the same. What we asked for was just a glass partition with no door (kind of like the example attached but with a strip drain at the end). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I think we've given up on it now anyway. If thats the price they want to charge its not worth doing and we'll stick with the original plan of a semi frameless screen and door that will go wall to wall. Follow my build here: https://www.instagram.com/ivy5custom Re: Quote for partition shower screen - is it unreasonable? 4Sep 24, 2020 11:13 am Bebbsy The shower alcove in our main bathroom is 2400mmx1000mm. Unsure if it’s the same as you call a partition wall, but we have what our builder describes as nib walls at either end of the shower alcove, with a wide glass door and a narrow fixed glass panel in between. Each nib wall (2700mmx600mm) cost $210 which included full height wall tiling on the shower side. We also have a 900mm strip drain at one end of the shower, the tiled floor is sloped to allow all water to flow into that drain. The drain was an additional $400. Total cost $810. Hi Bebbsy thanks for sharing the details. By any chance do you have a photo of your installation ? Thanks Re: Quote for partition shower screen - is it unreasonable? 5Sep 24, 2020 12:21 pm Ozshaz Bebbsy The shower alcove in our main bathroom is 2400mmx1000mm. Unsure if it’s the same as you call a partition wall, but we have what our builder describes as nib walls at either end of the shower alcove, with a wide glass door and a narrow fixed glass panel in between. Each nib wall (2700mmx600mm) cost $210 which included full height wall tiling on the shower side. We also have a 900mm strip drain at one end of the shower, the tiled floor is sloped to allow all water to flow into that drain. The drain was an additional $400. Total cost $810. Hi Bebbsy thanks for sharing the details. By any chance do you have a photo of your installation ? Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi all, Not sure if this is a good place for this question but I guess we'll find out! I'm a novice, building a modular room inside my garage/shed and need to create… 0 1850 i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98619 Your shower screen has failed in the way it is designed to fail with tempered glass. You could replace it with laminated safety glass but make sure it has AS standards logo on it 1 11160 |
