Browse Forums Building A New House Re: Rainwater tank location 2Sep 16, 2020 2:06 pm The builder, in my opinion and experience, is wrong. A slab also adds to a tank's height above the ground level, is he also disregarding this? Does he also think that a house built on a cut site has a lower roof height? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater tank location 3Sep 19, 2020 12:16 pm SaveH2O The builder, in my opinion and experience, is wrong. A slab also adds to a tank's height above the ground level, is he also disregarding this? Does he also think that a house built on a cut site has a lower roof height? Thank you. They are arguing that “existing” ground level was the basis. Since the site was cut by 300mm, up to 1800 + 300mm will be compliant. The tank is 1900mm + 150mm slab is within the range of what is compliant. This should just be based on finished ground level. I don’t understand why existing ground level was used. My RWT is now perched 600mm from the edge. Re: Rainwater tank location 4Sep 19, 2020 1:16 pm Have you verified with the council? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31284 Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 31167 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19521 |
