Browse Forums Building A New House 1 Sep 16, 2020 1:35 pm Hi, A neighbour's certifier has told me that my rainwater tank placement is not SEPP Compliant. Below is the guideline that he has pointed out is highlighted below: Subdivision 32 Rainwater tanks (above ground) 2.63 Specified development The construction or installation of a rainwater tank above ground is development specified for this code if it is not constructed or installed on land in a foreshore area or in an environmentally sensitive area. 2.64 Development standards (iii) be located at least 450mm from each lot boundary, if the tank has a height of more than 1.8m above ground level (existing), and (d) not rest on the footings of an existing building for support, and Our rainwater tank slab is connected to our house slab and is sitting less than 100mm from our boundary. The height of the tank 1900mm. My builder argued that the "ground level (existing)" is defined as the NGL or the level before the earthworks. Since the area where my rainwater tank is now was cut 300mm down, then it is compliant. Is the builder correct? The reasoning sounds silly basing it on the NGL. Moreover, I also argued that I have my rainwater tank slab connected to my house slab - an engineer told me once that it shouldn't have been done like that. Re: Rainwater tank location 2Sep 16, 2020 3:06 pm The builder, in my opinion and experience, is wrong. A slab also adds to a tank's height above the ground level, is he also disregarding this? Does he also think that a house built on a cut site has a lower roof height? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater tank location 3Sep 19, 2020 1:16 pm SaveH2O The builder, in my opinion and experience, is wrong. A slab also adds to a tank's height above the ground level, is he also disregarding this? Does he also think that a house built on a cut site has a lower roof height? Thank you. They are arguing that “existing” ground level was the basis. Since the site was cut by 300mm, up to 1800 + 300mm will be compliant. The tank is 1900mm + 150mm slab is within the range of what is compliant. This should just be based on finished ground level. I don’t understand why existing ground level was used. My RWT is now perched 600mm from the edge. Re: Rainwater tank location 4Sep 19, 2020 2:16 pm Have you verified with the council? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. 18 74251 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 24978 Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 25284 |
