Browse Forums Building A New House 1 Sep 13, 2020 1:15 pm Unfortunately I was a sucker and got pushed into pre-start quite quickly and took the bait. I'm afraid any changes I make will result in a big variation. Is it common for people to make changes after pre-start and are builders usually quite lenient? Re: How many changes do people generally make after pre-star 2Sep 13, 2020 10:44 pm If it's structural variation the cost can be very expensive. We were charged $7.5k to extend the rear of first floor by 800mm. The back of first floor is our master bedroom, ensuite and walk in robe. Our builder also wanted to charge us $3k to render just the porch. Re: How many changes do people generally make after pre-star 3Sep 14, 2020 1:14 pm Have you signed your building contract yet? If not, you still have room for negotiation if you are skilful enough! While you still have the ability to walk away, you still have the power. Losing your deposit is not a huge deal (and if you moved builders they would probably credit you this back) compared to being locked in to build with them. Not sure who you're building with, but I moved in recently to a 11month scheduled, 8 month actual build on the South coast/Illawarra NSW 3 5908 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10083 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61361 |
