Browse Forums Building A New House Re: Help - island bench has a join 2Sep 06, 2020 11:02 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Help - island bench has a join 6Sep 12, 2020 4:29 pm https://thomasarcherbuild.blogspot.com/p/blog-page.html - Thomas Archer Homes - Custom Nouveau 41 Re: Help - island bench has a join 8Sep 13, 2020 8:32 pm Blacktea2sugars Hmmmmm How disappointing. If you have documentation that a single piece of Silestone can be done to 3.5 and 1.2 w, then you should be ok. They only join to save costs and labour etc. No point accepting it if you're not happy with it. We went for a specific size island bench to make SURE there was a single piece of stone involved. I'm sure you did the same thing. Get the builder to get the mason back and redo it in 1 piece. Thanks. I'll try to contact Silestone if they can provide that info as I don't have it. Also I've already requested with my builder but they didn't listen. We may end up changing it after hand over but such a waste of money since we paid so much to upgrade to a stone. Re: Help - island bench has a join 9Sep 13, 2020 10:00 pm It's a difficult one. The stone mason's will have maximised the slabs. The most economical way to cut the whole kitchen may have meant putting a join through the island. If you went to the builder and stipulated that the island had to be a full slab then they may have ended up having to purchase an extra slab to achieve it, so the builder in an attempt to save money will gone with the join and it would have been cheaper for you as well. Really it comes down to your documentation and it sounds like it's in the builders favour. I know when I built the cabinets for our house I wanted to have our island (3.0x1.4) in one slab. In order to do the underside of the overhang it meant we had to get 2 sheets so I ended up using the rest of the slab in our bathrooms and laundry. It only cost me the labour to make. Of course the other possibility is Silestone didn't have any jumbo sheets in stock so you were going to have a join regardless. There have been numerous supply chain issues in recent times. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Help - island bench has a join 10Sep 14, 2020 8:56 pm chippy It's a difficult one. The stone mason's will have maximised the slabs. The most economical way to cut the whole kitchen may have meant putting a join through the island. If you went to the builder and stipulated that the island had to be a full slab then they may have ended up having to purchase an extra slab to achieve it, so the builder in an attempt to save money will gone with the join and it would have been cheaper for you as well. Really it comes down to your documentation and it sounds like it's in the builders favour. I know when I built the cabinets for our house I wanted to have our island (3.0x1.4) in one slab. In order to do the underside of the overhang it meant we had to get 2 sheets so I ended up using the rest of the slab in our bathrooms and laundry. It only cost me the labour to make. Of course the other possibility is Silestone didn't have any jumbo sheets in stock so you were going to have a join regardless. There have been numerous supply chain issues in recent times. Thanks chippy. Appreciate the info. Very helpful. Would it be possible to change the stone later on in one full slab without having to remove the waterfall ends or it will be a mess? Or removing the entire stone including the waterfall end is the only option? Re: Help - island bench has a join 11Sep 14, 2020 9:29 pm The waterfalls make it very hard. The joins are epoxied together so it's not so simple to pull it all apart. It's quite likely that the mitre along the waterfall end will break and chip so you'd more than likely end up pulling it all out and doing it again. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Help - island bench has a join 12Sep 14, 2020 9:35 pm chippy The waterfalls make it very hard. The joins are epoxied together so it's not so simple to pull it all apart. It's quite likely that the mitre along the waterfall end will break and chip so you'd more than likely end up pulling it all out and doing it again. Thanks. Oh no! We should have gone to laminate but anyway, good to hear that there is still an option. Due to costs, I guess we'll just change it once the join become very visible and when it starts to separate. Re: Help - island bench has a join 13Sep 14, 2020 9:51 pm Good cabinetry and a good stone mason and the join should never open up. Never know, you may just get used to it. When you are building it's very easy to focus on small details that a visitor would never notice. Having said that, it's you that will live there and sometimes you can't unsee some thing's that will stand out every time you look at it. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Help - island bench has a join 14Oct 16, 2020 9:52 am chippy Good cabinetry and a good stone mason and the join should never open up. Never know, you may just get used to it. When you are building it's very easy to focus on small details that a visitor would never notice. Having said that, it's you that will live there and sometimes you can't unsee some thing's that will stand out every time you look at it. Thanks😊 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6580 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11675 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31248 |
