Browse Forums Building A New House Re: Hebel, Electrical & Door's Questions 6Aug 30, 2020 6:34 pm Thanks for the info. Do you know what would be thickness of the wall with hebel 50mm. Looking at the drawings seems like it’s drawn as 190mm. I know with bricks it’s 240mm. With 90mm stud framework and 50mm hebel it’s like 50mm for insulation ? Does it sound right ? I was looking at different options for a fence for my build and Hebel PowerFence seemed like a good option (one of the criteria was a solid wall look). However, I don't… 0 5871 1 6601 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6174 |
