Browse Forums Building A New House 1 Aug 22, 2020 7:40 pm Hi, We are building new home & It is in lock up stage. We want to do small change (add internal door for walk in pantry) & Our builder has quoted $1275 to adopt this change. While we have got quote from our own handyman who has quoted for $400. I asked builder if they can allow my handyman on building site to finish this work. Builder is saying that QBCC will NOT allow & QBCC will give them penalty & demerit points on license. I am checking below link & this page has some different details. https://qualifyme.edu.au/qm-blog/qbcc-w ... ce-in-qld/ As per above link "a handyman – as long as the value is no more than $3,300, isn’t electrical or plumbing work and doesn’t require an occupational licence." Anyone can help what is the rule? Regards, Chetan Re: Want to hire handyman on Building site instead Builder's 2Aug 23, 2020 10:07 am Take possession of the build after handover and do whatever you want 4 times (cost) is the general rule... if you want it pay up, or go without, or do it later. Of course if its the siteworks or engineering...then your get you pants pulled down... as there is no other option but to accept it or walk away. hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6275 Sounds like rubbish to me. Ask for the contamination report which I doubt they have. If it's part of a normal subdivision it would have had a contamination report done… 9 5641 |
