Download fine for me again Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅
Browse Forums Building A New House Re: URGENT HELP NEEDED BAL RATING 22Oct 11, 2020 12:43 am Our build is at lockup in W.A and BAL 19. 340m2 total area and added 7.5k to build. 5mm toughened glass all around. Full anticon to roof. Steel fly screens. Rated front door no holes greater than 3mm anywhere. If your builder thinks that you require double glazing then walk away as he has no idea of the standards. Re: URGENT HELP NEEDED BAL RATING 23Oct 12, 2020 8:23 am Thank you all for your help, I know what the standards are but the builder is stating they gave our floorplan to A&L windows and they said we need double glazing. I will make further phone calls today. Re: URGENT HELP NEEDED BAL RATING 26Oct 13, 2020 8:34 am Does anyone know if this would be true or not? What is the difference between 5mm toughened and double glazing in relation to an energy report? Does the double glazing still comply with the Bal 19 standards? Thanks Re: URGENT HELP NEEDED BAL RATING 27Oct 13, 2020 9:21 am The structural Integrity ie loads, forces ,fire, etc, takes precedence over energy , but you will often hear builders, designers and building surveyors say they are equally important and quote some deem to comply ( DTC) solution where alternatives can be engineered and certified. Double glazed 5mm Toughened glazing is over kill ( lol, Units megabucks instead of megajoules) The codes allow engineers to provide (alternates to DTC) in the way of Modelling simulations/analysis/engineering Bim and Building surveys have to certify them. Your problem will be the builder has no interest in reducing costs as it reduces his profits. OT, On difficult and complicated builds it's always advisable to have your own certified engineering modelling data. Then get 3 builders to quote, when a builder comes back and tries to burn you (excuse the pun) with additional cost loadings (megabucks) ask for the engineered data and certified proofs (megajoule's). Hint Thermal properties of Rollers shutters Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: URGENT HELP NEEDED BAL RATING 28Oct 13, 2020 10:12 pm aussieta Doozer1905 Download fine for me again could you post the link you are using Re: URGENT HELP NEEDED BAL RATING 29Oct 14, 2020 8:49 am Thanks Chris, it is double glazing in lieu of 5mm toughened glass required by bal 19. I don’t know the properties of the double glazing. I will check out the roller shutters. Thank you. Thanks Doozer 1905 look to the link. Re: URGENT HELP NEEDED BAL RATING 30Oct 14, 2020 9:00 am https://infostore.saiglobal.com/en-au/s ... predictive You need to change it to the 1 user PDF copy and it will change the price from $256.45 to Free 3 4248 10 years ago was a different software than we use now. it has had a lot of changes over the past years. Improvments to the software and changes to how Nathers models need… 8 1581 |
