Browse Forums Building A New House 1 Aug 18, 2020 12:53 pm I have had to terminate my current builder for two townhouses midway through the frame stage due to poor performance. My question is has anyone had experience of the process to change over builders and how was the line of responsibility drawn between the new and old builder? For context 1 - Termination was the last option after many months trying to resolve the performance issues of the previous builder. The situation with the previous builder is irretrievable 2 - I have had several quotes from other builders to take over the work 3 - The problem I have is that the contract offered by the builder is very blunt that I has an owner have to warrant the works of the previous builder. I am not a builder and can't warrant what the previous builder has done. I have suggested an engineer investigate the works and draw a line between the works by the previous builder and the new builder but have had push back. Keen if anyone can share their experience of changing builders mid-build what was the structure of the contract to distinguish between the old and new builder. Re: Process to Change Builder 2Aug 18, 2020 1:40 pm Hey Kangaroobuilder Welcome to the forum yes you will need to get the current build assessed by a Building surveyor and Engineer Your new builder will try to get you to sign a cost plus contract also fill out the appropriate forms to transfer the build, ,pay the required insurances, goodluck with Banks,etc,etc I do recommend you also get legal advice Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Process to Change Builder 3Aug 18, 2020 9:31 pm StructuralBIMGuy Hey Kangaroobuilder Welcome to the forum yes you will need to get the current build assessed by a Building surveyor and Engineer Your new builder will try to get you to sign a cost plus contract also fill out the appropriate forms to transfer the build, ,pay the required insurances, goodluck with Banks,etc,etc I do recommend you also get legal advice Cheers Chris Thanks Chris (StructuralBIMGuy) Lined up the Engineer and Building Surveyor to do the assessments plus have a lawyer. Tricky bit is the 'Warranty Insurance' the frame is built by the old builder and fit out is by the new one. If there is defect where to draw the line, is there a permanent grey area? Could there be an intervention that helps solidify the line as much as possible? Regards, Kangaroobuilder Re: Process to Change Builder 4Aug 19, 2020 8:55 am KangarooBuilder Lined up the Engineer and Building Surveyor to do the assessments plus have a lawyer. Tricky bit is the 'Warranty Insurance' the frame is built by the old builder and fit out is by the new one. If there is defect where to draw the line, is there a permanent grey area? Could there be an intervention that helps solidify the line as much as possible? The Building surveyor (BS) will deal with NCC compliance issues while the Engineer should deal with code non compliance and remedies/fixes, they will work together to define your build, the lawyer will deal with contractual obligations simultaneously. OT, I hope you have properly inspected and documented each completed structural stage with BS& Eng Reports Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Process to Change Builder 5Aug 19, 2020 12:07 pm StructuralBIMGuy KangarooBuilder Lined up the Engineer and Building Surveyor to do the assessments plus have a lawyer. Tricky bit is the 'Warranty Insurance' the frame is built by the old builder and fit out is by the new one. If there is defect where to draw the line, is there a permanent grey area? Could there be an intervention that helps solidify the line as much as possible? The Building surveyor (BS) will deal with NCC compliance issues while the Engineer should deal with code non compliance and remedies/fixes, they will work together to define your build, the lawyer will deal with contractual obligations simultaneously. OT, I hope you have properly inspected and documented each completed structural stage with BS& Eng Reports Cheers Chris thanks yes I have reports that have been approved through the construction. Seems like bases are covered (so far) thanks for your inputs. Re: Process to Change Builder 6Jul 05, 2023 10:11 pm KangarooBuilder I have had to terminate my current builder for two townhouses midway through the frame stage due to poor performance. My question is has anyone had experience of the process to change over builders and how was the line of responsibility drawn between the new and old builder? For context 1 - Termination was the last option after many months trying to resolve the performance issues of the previous builder. The situation with the previous builder is irretrievable 2 - I have had several quotes from other builders to take over the work 3 - The problem I have is that the contract offered by the builder is very blunt that I has an owner have to warrant the works of the previous builder. I am not a builder and can't warrant what the previous builder has done. I have suggested an engineer investigate the works and draw a line between the works by the previous builder and the new builder but have had push back. Keen if anyone can share their experience of changing builders mid-build what was the structure of the contract to distinguish between the old and new builder. Hey, just wanted to see how you went with obtaining a new builder as you had already started construction? I too am in the same boat. Was it a difficult process? Any advice? Thank you so much Re: Process to Change Builder 7Jul 06, 2023 4:42 pm Buildinglife KangarooBuilder I have had to terminate my current builder for two townhouses midway through the frame stage due to poor performance. My question is has anyone had experience of the process to change over builders and how was the line of responsibility drawn between the new and old builder? For context 1 - Termination was the last option after many months trying to resolve the performance issues of the previous builder. The situation with the previous builder is irretrievable 2 - I have had several quotes from other builders to take over the work 3 - The problem I have is that the contract offered by the builder is very blunt that I has an owner have to warrant the works of the previous builder. I am not a builder and can't warrant what the previous builder has done. I have suggested an engineer investigate the works and draw a line between the works by the previous builder and the new builder but have had push back. Keen if anyone can share their experience of changing builders mid-build what was the structure of the contract to distinguish between the old and new builder. Hey, just wanted to see how you went with obtaining a new builder as you had already started construction? I too am in the same boat. Was it a difficult process? Any advice? Thank you so much I have been through it a couple of times so happy to chat to you offline and explain the pros and cons. if you like give me a call on 0431712792. cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Been in a similar position and we decided to let the builder go. Some of the PSA money goes to engineering so we at least got those documents and they actually refunded us… 2 4562 I apologise for any confusion, but your understanding is correct. We approached our situation differently based on advice from… 11 37636 Thanks very much! And would the landscaper/contractor generally involve the engineer or is that something the client would do? Thanks for your help 2 6754 |
