Browse Forums Building A New House Re: Building with Wisdom Homes 9941Mar 22, 2018 3:44 pm Thank you We signed off on a 10k figure. What confused me is the wording on contract saying final quote on landscaping will be after construction has commenced. You know that document where you say yes/no. Ours came to just under 10k. So the EP should be that 10k figure. Re: Building with Wisdom Homes 9942Mar 22, 2018 3:55 pm ASJ1981 Thank you We signed off on a 10k figure. What confused me is the wording on contract saying final quote on landscaping will be after construction has commenced. You know that document where you say yes/no. Ours came to just under 10k. So the EP should be that 10k figure. Building WH Manhattan 44 Ensuite Production Estimates: 13 Nov 2017 DA Approval : 25 October 2017 Contract Sign: 28 May 2017 Tender Sign: 24 April 2017 Request for Tender: 22 Jan 2017 Re: Building with Wisdom Homes 9943Mar 22, 2018 4:01 pm lombieagle ASJ1981 Thank you We signed off on a 10k figure. What confused me is the wording on contract saying final quote on landscaping will be after construction has commenced. You know that document where you say yes/no. Ours came to just under 10k. So the EP should be that 10k figure. Thank you Makes perfect sense! Re: Building with Wisdom Homes 9944Mar 22, 2018 4:46 pm SejaeD any idea how they are secured to the footings to stop them being stolen as they only weigh 24kg? You put down a concrete footing and bolt it into the concrete from the inside with dynabolts- similar to putting down footings for a deck. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Re: Building with Wisdom Homes 9945Mar 22, 2018 4:54 pm Jenifermarie SejaeD any idea how they are secured to the footings to stop them being stolen as they only weigh 24kg? You put down a concrete footing and bolt it into the concrete from the inside with dynabolts- similar to putting down footings for a deck. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Thats what i was thinking, so wont it cost close to $500 to get the footing installed? Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 9946Mar 22, 2018 7:02 pm SejaeD Jenifermarie SejaeD any idea how they are secured to the footings to stop them being stolen as they only weigh 24kg? You put down a concrete footing and bolt it into the concrete from the inside with dynabolts- similar to putting down footings for a deck. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Thats what i was thinking, so wont it cost close to $500 to get the footing installed? We will do it ourselves. It’s not difficult to lay down a small footing. Essentially dig a hole, mix up some concrete, dump it in the hole and level it off. Out of all the DIY projects when we move in that’s the least daunting! Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Re: Building with Wisdom Homes 9947Mar 22, 2018 7:09 pm ASJ1981 Hi guys, Quick question. I'm about to submit and send off our Provisional Landscape Allowance. Planning to get Driveway done only and possibly Rendered Letterbox. There is an item for "Fill Removal x 2 Mixed Loads $1,450* - Site Prep x 1 and Driveway x 1. *Alternatively fill can be stockpiled for removal by owner. Total Cost is $2,900. Is it easy to remove after handover? Lastly, is the Rendered Letterbox worth the $1050? Tried to google it to see if there are any local businesses that do this, but struggled to find one! TIA! I think the dirt removal is expensive but I cant be bothered organising that so got WL to remove it for me also. Just for the convenience. We got the rendered letterbox from WL, you could probably get it a little cheaper if you went private, but you'll need to get a brickie that can render, else it will just be a hassle to find the right peoples. Check my blog if you'd like to see what it looks like. Wisdom Homes Manhattan 39 Blog - https://edmondson-park.blogspot.com.au H1 Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=88210 Re: Building with Wisdom Homes 9948Mar 22, 2018 7:13 pm ozmonkeyoy Hey SejaeD, Hope all is well. My lintel issue still remains unresolved. Builder has put it squarely on the engineer to make the call, am awaiting their latest response. In regards to topic at hand (letterbox); Just for others info, the letterbox that WL does, does supply all of the above, just just need to paint it yourself. Hmm we didn't need to paint our letterbox. At colour selection they asked what colour we wanted and it was done in that colour. Wisdom Homes Manhattan 39 Blog - https://edmondson-park.blogspot.com.au H1 Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=88210 Re: Building with Wisdom Homes 9949Mar 22, 2018 7:14 pm Jenifermarie ASJ1981 Hi guys, Quick question. I'm about to submit and send off our Provisional Landscape Allowance. Planning to get Driveway done only and possibly Rendered Letterbox. There is an item for "Fill Removal x 2 Mixed Loads $1,450* - Site Prep x 1 and Driveway x 1. *Alternatively fill can be stockpiled for removal by owner. Total Cost is $2,900. Is it easy to remove after handover? Lastly, is the Rendered Letterbox worth the $1050? Tried to google it to see if there are any local businesses that do this, but struggled to find one! TIA! We were planning to get a rendered mailbox but I’m thinking I might just cut it back to our driveway now. I’ve found this mailbox which is half the price, looks better than the Bunnings ones everyone has, they do custom face plate and it holds parcels. http://www.deliver-eze.com.au/pillar/ Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Gah. Our estate guidelines state minimum 450mm wide. I wonder if they’d be picky about 1cm?! They offer a rebate of $5k or I wouldn’t care lol Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 9950Mar 22, 2018 7:30 pm Has anyone building in a new estate not followed landscaping requirements and had problems? We installed colorbond side gates against estate guidelines thinking we would just have to forgo our rebate (a measly 1k). They’ve sent us a letter stating we have to comply or they would take ‘further action’. I didn’t think the estate guidelines were legally enforceable? As long as we covered our council requirements? Any ideas? They want gates that you can see through (aluminium slats with gaps), I don’t want my dogs driving the neighbours mad barking at everything they see go past. majestic35.weebly.com Re: Building with Wisdom Homes 9951Mar 22, 2018 7:43 pm Rocchet Has anyone building in a new estate not followed landscaping requirements and had problems? We installed colorbond side gates against estate guidelines thinking we would just have to forgo our rebate (a measly 1k). They’ve sent us a letter stating we have to comply or they would take ‘further action’. I didn’t think the estate guidelines were legally enforceable? As long as we covered our council requirements? Any ideas? They want gates that you can see through (aluminium slats with gaps), I don’t want my dogs driving the neighbours mad barking at everything they see go past. A lot of people (like maybe half) in my estate have decided to forgo the rebate because they didn’t want a 3m driveway width at the crossover, or because they didn’t want to plant trees etc and no one has had a problem that I know of. I’d probably just see what they do. Worse case they can somehow force you to take them down, they aren’t going to be able to fine you or something...I don’t think? Lol Have you explained to them about the dogs? Our developers allowed some people to have a wider driveway because they were on corner lots, maybe yours will be similar because you have good reason. Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 9952Mar 23, 2018 6:40 am Rocchet Has anyone building in a new estate not followed landscaping requirements and had problems? We installed colorbond side gates against estate guidelines thinking we would just have to forgo our rebate (a measly 1k). They’ve sent us a letter stating we have to comply or they would take ‘further action’. I didn’t think the estate guidelines were legally enforceable? As long as we covered our council requirements? Any ideas? They want gates that you can see through (aluminium slats with gaps), I don’t want my dogs driving the neighbours mad barking at everything they see go past. Our land contract included a special clause that says we’re bound to adhere to the estate guidelines so I would assume it is legally enforceable based on it being in our contract. Having said that I’ve not heard of anywhere being that strict about them. Do they give you any option to appeal/explain yourself? I’m surprised they have picked it up to enforce it. I wonder if it’s like living in a strata complex that they only bother to enforce it if someone complains. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Re: Building with Wisdom Homes 9955Mar 23, 2018 8:08 am Great news! Must have been a good feeling to see that this morning. How far is your setback? It looks like a long way back from the road. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Re: Building with Wisdom Homes 9956Mar 23, 2018 8:14 am Jenifermarie Great news! Must have been a good feeling to see that this morning. How far is your setback? It looks like a long way back from the road. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Re: Building with Wisdom Homes 9957Mar 23, 2018 8:42 am Jenifermarie Rocchet Has anyone building in a new estate not followed landscaping requirements and had problems? We installed colorbond side gates against estate guidelines thinking we would just have to forgo our rebate (a measly 1k). They’ve sent us a letter stating we have to comply or they would take ‘further action’. I didn’t think the estate guidelines were legally enforceable? As long as we covered our council requirements? Any ideas? They want gates that you can see through (aluminium slats with gaps), I don’t want my dogs driving the neighbours mad barking at everything they see go past. Our land contract included a special clause that says we’re bound to adhere to the estate guidelines so I would assume it is legally enforceable based on it being in our contract. Having said that I’ve not heard of anywhere being that strict about them. Do they give you any option to appeal/explain yourself? I’m surprised they have picked it up to enforce it. I wonder if it’s like living in a strata complex that they only bother to enforce it if someone complains. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Hi Guys I can help out with this thread as I have been through a similar thing and had it tested in court. Council's LEP and DCP guidelines override any condition in an estate guideline or strata by laws where there are differences. As a developer, I built an estate of 40 factory/warehouse units. We had clear by laws saying that no factory could be used as a drug injecting room or brothel. This was made clear to every purchaser before contracts were exchanged. A lot of people bought into the complex seeing this as a major positive. One owner decided to convert his unit to a brothel so the body corporate took him to court. They lost as Parramatta's LEP allowed for sex premises in that zoning. So you need to check the DCP for fencing guidelines. Sometimes the developer will have input into the DCP and the estate guidelines line up with the DCP controls. Hope this helps Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 9959Mar 23, 2018 8:55 am Chompy Quick question (not as exciting as seeing everyone’s progress!) What is the cost of including built in desks in bedrooms (similar to display homes) from timpelle. Are these a good idea? Hi Chompy, We got quoted $2,300 for a built in study desk for our home office. It was about 2.85m long and 2 x cabinets on each side. We opted not to take it though. I must admit, custom made built-ins do look fabulous though! We did not request a quote for the media, leisure or 1st floor rumpus and wish we did though. the reason we decided not to go ahead with it was because i wanted them all to match for consistency and because we didnt ask for the others to be quoted, we might just leave it for now. I have awhile to do more homework on that stuff anyway. Re: Building with Wisdom Homes 9960Mar 23, 2018 9:03 am Chompy Quick question (not as exciting as seeing everyone’s progress!) What is the cost of including built in desks in bedrooms (similar to display homes) from timpelle. Are these a good idea? Chompy if you go through the builder, with their mark up its going to be incredibly expensive. What we are doing and have done in the past is go to a local kitchen joiner and get them custom made. Joiners will build you anything laminated or polyurethane. I have a great joiner based at Smithfield who has built heaps of stuff for me over the years. If you want his details PM me. But if you look in your local paper you will find a bunch of them. They are the same guys that the majors use but without a 30-40% markup Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 19480 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 75122 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 9827 |
