Browse Forums Building A New House Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 61Aug 22, 2014 10:09 am Hey Joea I wanted my garage extended as well.....PD did all the drawings and provided the cost....but you'll need to check with your developer if you can build your garage right up to the fence line. Some estates have a building envelope which limits your building to a confined area Better to double check....thats the one thing I really wanted for my build....a man cave garage....but was denied by developer Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 62Aug 22, 2014 11:40 am Filthyfil Hey Joea I wanted my garage extended as well.....PD did all the drawings and provided the cost....but you'll need to check with your developer if you can build your garage right up to the fence line. Some estates have a building envelope which limits your building to a confined area Better to double check....thats the one thing I really wanted for my build....a man cave garage....but was denied by developer Hi Filthyfil, Thanks for that. I'm pretty sure we can do this. I've attached the screenshot from the design guideline from our estate. The thing that scares me is that it states: "Single storey walls and garages must comply with point 10 above, or must be built to the boundary if the design can be justified by demonstrating efficiency and amenity benefits." Does that mean we can't have a 200mm offset from the boundary? Oh man... I really don't want to have the garage wall on the fence line...Just when I thought it was sorted. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 63Aug 22, 2014 12:29 pm joea Filthyfil Hey Joea I wanted my garage extended as well.....PD did all the drawings and provided the cost....but you'll need to check with your developer if you can build your garage right up to the fence line. Some estates have a building envelope which limits your building to a confined area Better to double check....thats the one thing I really wanted for my build....a man cave garage....but was denied by developer Hi Filthyfil, Thanks for that. I'm pretty sure we can do this. I've attached the screenshot from the design guideline from our estate. The thing that scares me is that it states: "Single storey walls and garages must comply with point 10 above, or must be built to the boundary if the design can be justified by demonstrating efficiency and amenity benefits." Does that mean we can't have a 200mm offset from the boundary? Oh man... I really don't want to have the garage wall on the fence line...Just when I thought it was sorted. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wheres your neighbours crossover? Is their garage going to be next to yours? How much setback do you have on the other side of the house? Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 64Aug 22, 2014 12:39 pm sogg joea Filthyfil Hey Joea I wanted my garage extended as well.....PD did all the drawings and provided the cost....but you'll need to check with your developer if you can build your garage right up to the fence line. Some estates have a building envelope which limits your building to a confined area Better to double check....thats the one thing I really wanted for my build....a man cave garage....but was denied by developer Hi Filthyfil, Thanks for that. I'm pretty sure we can do this. I've attached the screenshot from the design guideline from our estate. The thing that scares me is that it states: "Single storey walls and garages must comply with point 10 above, or must be built to the boundary if the design can be justified by demonstrating efficiency and amenity benefits." Does that mean we can't have a 200mm offset from the boundary? Oh man... I really don't want to have the garage wall on the fence line...Just when I thought it was sorted. Wheres your neighbours crossover? Is their garage going to be next to yours? How much setback do you have on the other side of the house? Neighbour's cross over is on the other side according to the Engineering docs. So their garage won't be next to ours. Our set back on the other side is 1.4m. Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 65Aug 22, 2014 12:45 pm Filthyfil Hey Joea I wanted my garage extended as well.....PD did all the drawings and provided the cost....but you'll need to check with your developer if you can build your garage right up to the fence line. Some estates have a building envelope which limits your building to a confined area Better to double check....thats the one thing I really wanted for my build....a man cave garage....but was denied by developer You scared me so I went on a little search.... Found this: http://dsewebapps.dse.vic.gov.au/shared/ats.nsf/%28attachmentopen%29/4D5B328F3B7CBE56CA257B1E0081D90A/$File/Melton+C137+Incorporated+Document+-+Small+Lot+Housing+Code++Approval+Gazetted.pdf?OpenElement http://planningschemes.dpcd.vic.gov.au/schemes/combined-ordinances/Hume_PS_Ordinance.pdf It seems that 'on the boundary' means within 200mm of the boundary. Should be ok Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 66Aug 22, 2014 12:51 pm joea Neighbour's cross over is on the other side according to the Engineering docs. So their garage won't be next to ours. Our set back on the other side is 1.4m. You will be fine then, i think you would of had a problem if u had less than 1.2meters on the other side Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 67Aug 22, 2014 12:53 pm sogg joea Neighbour's cross over is on the other side according to the Engineering docs. So their garage won't be next to ours. Our set back on the other side is 1.4m. You will be fine then, i think you would of had a problem if u had less than 1.2meters on the other side Oh great. Yea I have a picture on the previous page showing the distance from the other side. Fingers crossed. Cheers for the help Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 68Sep 17, 2014 11:27 am Hi all, We finally managed to get our colour/electrical done on Monday. Overall we were quite disappointed in the process. It was rushed (VERY rushed) especially the initial colour selections. We found out that one of the colours we wanted to use for our island 'Basalt' is not used by Porter Davis for cupboards. They only use it for bench tops and panels. Go figure. Really disappointing considering when we visited the showroom prior to our appointment all the 'Consultants' never mentioned anything about this. Of course, this basically forced us to change most of our cabinetry colours. At the end of the day, they seemed to have plenty of time to run us over the curtains and blinds (to get more money of course). However with 15mins left we were meant to review our entire days work. Yea right... Took our time doing this even going overtime, then we found many mistakes in the document. When we asked to get this amended before we sign, the response was that no we cannot do that or write comments on the document. 'Please send us an email to fix these errors'. As you can imagine after a long day of decisions and being 5:30pm I was absolutely fuming but I was reassured this was the 'correct' process to follow. The end result? Stressing out during the 48hr 'cool off' period to get all the correct colours in the documents, which meant countless emails between ourselves and the Consultant. Also, we are very unsure about our final colour selection, even though we had done countless hours of research and visited the showroom many times before our appointment. Having said all that, the electrical appointment was great. The consultant was very thorough and helpful and made sure we took our time with making each and every decision. She also made some great suggestions along the way. Once I cool down a bit, I will post up our 'Final' colour selections and hope to get some feedback from some forum members. Thank you and sorry for the rant! Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 69Sep 17, 2014 3:37 pm Hey Joea Exactly the same experience as me. You know what I did in the end? I ask for the cabinetry / colors to mirror the display home I liked. Prob cost me a bit more, but it's a piece of mind And yes, electrical were great... Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 70Sep 17, 2014 3:56 pm Filthyfil Hey Joea Exactly the same experience as me. You know what I did in the end? I ask for the cabinetry / colors to mirror the display home I liked. Prob cost me a bit more, but it's a piece of mind And yes, electrical were great... Hi Filthyfil, I should have done that! Would have been much easier that way. Cheers. Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 71Sep 17, 2014 4:01 pm You still can......I originally went for my own color scheme...then decided to go with the display I liked Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 72Sep 17, 2014 4:27 pm Filthyfil You still can......I originally went for my own color scheme...then decided to go with the display I liked I'd be more than happy with that but I don't think my better half would agree. Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 73Sep 22, 2014 9:25 am Hi All, We went out to have a look at our block yesterday. It's so exciting to final see it come together. Only thing we spotted was that the street light is right in front of our block and next to our crossover which is why we couldn't move the crossover in the first place. Would have been nice to have been given this information before we signed. Anyways no big deal I guess. Almost done Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 74Sep 22, 2014 9:27 am Congrats mate....exciting times ahead. Hanging out to see that aquarium.... Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 75Sep 22, 2014 9:34 am Filthyfil Congrats mate....exciting times ahead. Hanging out to see that aquarium.... Thank you very much. Yes definitely, it has been almost a year since we begun this journey and it's good to see all the hard work and research paying off. Me too! Can't wait to have it up and running. Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 76Sep 23, 2014 1:58 pm Looking good. When is it supposed to title? Know exactly how you feel, been a long road for us too. Glad it's all coming together for you. Our place has started, but our Hopetoun doc is still changing. Expecting another one to be emailed to us this week. The whole colour choice system software they use is really screwy. Apparently they're working on fixing it. They found a bunch of errors and inconsistencies in ours at the end there, just as they were checking over it with their estimating team. As annoying as it is, I'm glad they spotted them and asked us to confirm what we wanted, I guess. Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 77Sep 23, 2014 3:10 pm Jasdan Looking good. When is it supposed to title? Know exactly how you feel, been a long road for us too. Glad it's all coming together for you. Our place has started, but our Hopetoun doc is still changing. Expecting another one to be emailed to us this week. The whole colour choice system software they use is really screwy. Apparently they're working on fixing it. They found a bunch of errors and inconsistencies in ours at the end there, just as they were checking over it with their estimating team. As annoying as it is, I'm glad they spotted them and asked us to confirm what we wanted, I guess. Estimated title timing is October sometime. I'm expecting late October. Thank you very much. Yes it can be a really daunting process, especially if you are a perfectionist like me. Even after we had done all our selections I still went back and re-checked everything. Luckily I did as I found many discrepancies. The system at World Of Style the new PD selections show room seems like it is much more robust than at Hopetoun Interiors. All our requested changes even after our selection date have already been received by our BC and implemented on our documents. I don't know if this is a reflection of a better system or more accurate staff. Just looking through your blog now, very nice build! Look forward to watching it progress. I'm glad PD has picked up some issues and made you aware of them, at least it means they have some sort of checking process. Are you using a Building Inspector? Cheers Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 78Sep 23, 2014 4:01 pm Thanks, looking forward to seeing yours go up as well - love the Dunedin. Haven't been to the new World of Style showroom. Too scared in case we see a zillion things we should've chosen. Not long to wait for the title, great news! Yeah we've not long lined up New Home Inspections to keep an eye on the build for us. Been recommended to us by several people now, see how we go. Are you planning on using someone too? Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 79Sep 23, 2014 4:15 pm Jasdan Thanks, looking forward to seeing yours go up as well - love the Dunedin. Haven't been to the new World of Style showroom. Too scared in case we see a zillion things we should've chosen. Not long to wait for the title, great news! Yeah we've not long lined up New Home Inspections to keep an eye on the build for us. Been recommended to us by several people now, see how we go. Are you planning on using someone too? Thank you, we love it too! Good thinking, that place is huge compared to Hopetoun and it will bring on the 'What if we do this?' or 'What if we chose this?'. Yes, just a few weeks (hopefully). Excellent, I have heard good things about NHI. Definitely, either Building Expert or Darebecca. They both seem like good options just have to make up our mind on which one we prefer. Re: Our first home Dunedin 29 Porter Davis - Merrifield,Vict 80Sep 24, 2014 11:36 am I have started a blog for our build. It's much easier to track compared to this build thread. http://dunedin29.blogspot.com.au/ Cheers 1. Roof cleaning and paint - which colour do you recommend? I often see black/ dark grey in use these days but I would prefer… 0 9192 Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 14042 0 5260 |
