Pedro4137
Often put on plan,
Never seen in engineering document
The other thing is not having temporary downpipes during construction not all builders do it
Browse Forums Building A New House Re: Slab cracks 61Jan 15, 2023 4:07 pm Pedro4137 Often put on plan, Never seen in engineering document The other thing is not having temporary downpipes during construction not all builders do it Re: Slab cracks 63Jan 16, 2023 12:35 pm Pedro4137 What OHS are builders complying with? Is it during construction Is this to me? A few different convos going on atm lol. Re: Slab cracks 64Jan 16, 2023 2:31 pm groundzero
5.6.3 Drainage requirementsBuildings on moderately, highly or extremely reactive sites shall be provided with drainage systems designed in accordance with the following:[ol] [/ol] anybody, what does this mean? drainage system/s? completed by the finish of construction of the building> interesting Re: Slab cracks 65Jan 16, 2023 3:22 pm Pedro4137 What OHS are builders complying with? Is it during construction Yes during construction early. I don't know exactly why but I believe it is for the tradies not to be walking on wet slippery ground around the outside of the slab. It would be good if a builder would tell us why the artificial gravel ramp is put down, I can't find any info regarding it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Slab cracks 66Jan 16, 2023 3:26 pm Mirrmu83 groundzero
5.6.3 Drainage requirementsBuildings on moderately, highly or extremely reactive sites shall be provided with drainage systems designed in accordance with the following: [ol] [/ol] anybody, what does this mean? drainage system/s? completed by the finish of construction of the building> interesting I'm assuming they mean the stormwater and sewer systems but must control surface drainage from the start of construction. Re: Slab cracks 67Jan 16, 2023 5:42 pm groundzero Pedro4137 What OHS are builders complying with? Is it during construction Yes during construction early. I don't know exactly why but I believe it is for the tradies not to be walking on wet slippery ground around the outside of the slab. It would be good if a builder would tell us why the artificial gravel ramp is put down, I can't find any info regarding it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Isn't it to protect the footings? Re: Slab cracks 68Jan 16, 2023 5:56 pm Matevieflick groundzero Pedro4137 What OHS are builders complying with? Is it during construction Yes during construction early. I don't know exactly why but I believe it is for the tradies not to be walking on wet slippery ground around the outside of the slab. It would be good if a builder would tell us why the artificial gravel ramp is put down, I can't find any info regarding it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Isn't it to protect the footings? No its actually one of the worst thing for the footings as it allows water into the ground but prevents it from evaporating so over time the soil at the edge of the slab becomes very wet and can cause slab heave. If your garden bed is dry then one way to wet the soil up is put tanbark down( mulching) this has the same effect around the edge of a slab. unfortunately it's common practice Re: Slab cracks 69Jan 16, 2023 6:35 pm groundzero Matevieflick groundzero Yes during construction early. I don't know exactly why but I believe it is for the tradies not to be walking on wet slippery ground around the outside of the slab. It would be good if a builder would tell us why the artificial gravel ramp is put down, I can't find any info regarding it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Isn't it to protect the footings? No its actually one of the worst thing for the footings as it allows water into the ground but prevents it from evaporating so over time the soil at the edge of the slab becomes very wet and can cause slab heave. If your garden bed is dry then one way to wet the soil up is put tanbark down( mulching) this has the same effect around the edge of a slab. unfortunately it's common practice Oh good to know. Thank you 😊 Re: Slab cracks 70Jan 16, 2023 7:16 pm groundzero Mirrmu83 groundzero
5.6.3 Drainage requirementsBuildings on moderately, highly or extremely reactive sites shall be provided with drainage systems designed in accordance with the following:[ol] [/ol] anybody, what does this mean? drainage system/s? completed by the finish of construction of the building> interesting I'm assuming they mean the stormwater and sewer systems but must control surface drainage from the start of construction. very confusing, is about surface water from titled land to the street? 1. (a) about engineering of footings The CSIRO BTF18 explains differnt types of cracks and what "normal" is Google this and the top result is actually the latest version. You normally have to buy this from… 9 9524 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11453 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17427 |
