It is looking fab. Not long now!!!
Browse Forums Building A New House Re: Custom Build in Warrnambool 522Jan 19, 2017 7:24 am Looks great!! Your family just needs your beautiful family to make it a home GJ Gardner Modified Coolum 277 viewtopic.php?t=83643 Re: Custom Build in Warrnambool 523Jan 19, 2017 9:34 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Some dirt has been moved around today. Dirt dug out where driveway crossover went has been put each side of the driveway which has neatened things up appearance wise significantly. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ NBN has been installed into the pantry as requested. The gear is bigger than I even expected it to be! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Oven with splash back bit removed from inside. It still needs to be levelled. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Doors on the island have been replaced with handle-less ones! These are push to open and not super easy to bump open which was originally my concern with push to open in this location (think knees) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Fan controllers have been mounted. These are cool, the light control is on the same remote but it remembers how dimmed the light was, the switch turns on the fan/light and turns off both; but only then turns back on the light if it was on when switched off. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Blinds have been installed to the two doors that were missing them. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Porch ceiling has been trimmed and light fitting installed. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bricklayers have been back and sealed under the meterbox. Meterbox still not yet painted. The shed has been put on hold as the slab was 90mm out of square!! This will be fixed tomorrow/Saturday to allow the shed guys to start back on-site Monday or Tuesday of next week. Re: Custom Build in Warrnambool 525Jan 20, 2017 8:17 pm Gorgeous!! Oh wow your kitchen splash window view is so picturesque! It's like looking at a painting! C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Custom Build in Warrnambool 526Jan 20, 2017 8:50 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The drop sheet and other detritus was removed from the island bench today. It's funny because in photos it actually looks sort of small. I think because it's so thick it just looks like perspective, the jumbo pendants help fool the eye that way too - it's 1200x3000 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Air deflectors fitted to the AC unit. I can't find the photo I took of the side of the Daikin SkyFi unit so I can't connect the app to the aircon. Feck. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here's an image I've played with the colour/brightness in lightroom - closer to what it looks like to the eye. Re: Custom Build in Warrnambool 527Jan 23, 2017 11:59 pm We copped a bit of rain today - a timely reminder that we need to sort out some turf and some form of driveway pretty quick smart once we take back control of the site! It's very sticky! Electricians have been and run the power in trench to the shed. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The concreters have been there too - they've cut a section off one side of the slab and drilled/inserted reo bar to the other side and are looking ready to form up for a pour to square the slab up. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My brother was up in the roof installing a trap in the A/C drain and noticed our fans didn't have their draft stoppers fitted, so I've got the builder chasing that up. Also he mentioned it was very hot up there, no wonder as there's not yet a whirly bird vent on the roof. Another thing I have now reminded them to get on to. We couldn't get in this arvo to see what else has been done although I suspect it's been mostly external works today - I think the vinyl plank guy was back but without being able to get in to check it's hard to know for certain. It doesn't look like the painter has been in as none of the tape marks on the walls that we can see have moved. I connected my phone to the Daikin SkiFi unit and turned the AC on and off from outside the house. Kind of cool but a little slow and cumbersome to connect. There's a plugin available for Vera home automation controllers as well as a reverse engineered API so I've got some other options to send commands to the A/C utilising the SkiFi but without using their clunky software. Hopefully I can make the house able to point out if it's a much better idea to open some windows than to run the A/C (by checking the units measured outdoor temp vs room and desired temps) to help save energy. Re: Custom Build in Warrnambool 528Jan 24, 2017 12:06 am We've also got two of our three fences organised with our neighbours. The guy over the back is a builder so will do that one for a reasonable price, the side is a bit dearer as the posts have to go down behind our retaining wall. The far side remains a project to resolve as we have to sort a retaining wall there before we worry too much about fencing. We also have no neighbour on at least one block but the other looks like it's about to get frontage to JUST it - it seems like it might be a requirement for titling so I'm wondering if building will start there shortly after they seal the road and do the footpath for that block - if so we may have a neighbour to share half of the fence cost for the front half of the block. Wether we will then wait for a neighbour on the back half probably depends just how dear that bit ends up being. The plan is not to do that fence as high so as to not take out our view too much - because the house isn't built up against (or anywhere near) it, we shouldn't have issues with overlooking from any rooms etc... If we can get away with a low fence maybe 1m high it'll still be over 2m high from the neighbour's side when the retaining wall height is included. Re: Custom Build in Warrnambool 529Jan 24, 2017 8:14 pm Concreters have fixed the slab. Not sure when to expect the shed guys back. Australia day Thusday puts a bit of a hole in availability; hopefully they get back onto ours as a priority. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The oven has been levelled, but I can't really see what else has been done inside the house today (although we don't have access at the moment either) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Custom Build in Warrnambool 530Jan 25, 2017 11:30 pm Plenty of people onsite today but as we're not able to get in, it's hard to see exactly what got done inside. It looks like a lot of the blue defect indicators have been removed from the paint so hopefully those will pass a closer inspection. There's still a heap of paint on window frames etc where it shouldn't be - hoping that that just isn't fixed yet because they wait until they've finished putting paint on before taking any off. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Colorbond strips have been installed above the stackers and kitchen splash window to correct for the difference in head height Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Painters have also painted the NBN conduit, box and meterbox. The meterbox was supposed to be monument but I actually think I prefer it in terrain as it's a bit less in-your-face which in this location is a good thing; it'll end up being the only part of this services side in front of the side fence. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Theatre room privacy latch has been installed, this is so we can use this as a guest bedroom from time to time without the kids invading our guest's space. I'm getting a little worried about time-frame now, we haven't got a final invoice yet and I'm under impression the final payment process can take some time to do due to the bank valuation requirement and time to send out a bank cheque. I've emailed my broker to get a bit of a timeframe but might have to start pushing the builder on Friday to get the final invoice to us in anticipation of being completed enough for the valuer to look over the house during the week so we can get the payment process under way. Re: Custom Build in Warrnambool 531Jan 26, 2017 4:28 pm SileNceR Plenty of people onsite today but as we're not able to get in, it's hard to see exactly what got done inside. It looks like a lot of the blue defect indicators have been removed from the paint so hopefully those will pass a closer inspection. There's still a heap of paint on window frames etc where it shouldn't be - hoping that that just isn't fixed yet because they wait until they've finished putting paint on before taking any off. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Colorbond strips have been installed above the stackers and kitchen splash window to correct for the difference in head height Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Painters have also painted the NBN conduit, box and meterbox. The meterbox was supposed to be monument but I actually think I prefer it in terrain as it's a bit less in-your-face which in this location is a good thing; it'll end up being the only part of this services side in front of the side fence. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Theatre room privacy latch has been installed, this is so we can use this as a guest bedroom from time to time without the kids invading our guest's space. I'm getting a little worried about time-frame now, we haven't got a final invoice yet and I'm under impression the final payment process can take some time to do due to the bank valuation requirement and time to send out a bank cheque. I've emailed my broker to get a bit of a timeframe but might have to start pushing the builder on Friday to get the final invoice to us in anticipation of being completed enough for the valuer to look over the house during the week so we can get the payment process under way. It was 10 days from final invoice to keys for us - we picked our final payment up as a cheque from the bank and took it to the builder. I've heard if you do direct deposit it can take longer. Things are looking great! We built the Rathdowne with Simonds Express in Western Melbourne Site start Oct. 2015 Keys Jan. 25th, 2015 My build thread -here- Re: Custom Build in Warrnambool 532Jan 26, 2017 4:52 pm We've got our final invoice this morning so we can organise the bank cheque. Because we have been in so often through the build process we are pretty happy that we will be able to handover even if there are still a few little things to do - especially as Sarah will be off work for the following week Re: Custom Build in Warrnambool 533Jan 26, 2017 5:10 pm Looking great Silencer... I am sure you won't have any hiccups during handover... Re: Custom Build in Warrnambool 534Jan 26, 2017 7:56 pm Wow, I've just caught up with your thread, what a beautiful looking home! I adore your kitchen space, love your bricks too. You must be really pleased Re: Custom Build in Warrnambool 535Jan 27, 2017 7:13 pm Downpipes aren't neopolitan any more, just two colours now - much better. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I assume a lot of other painting work inside, but still no whirly bird on the roof and I can't get in to see if any other small things have been done Insurance organised and final invoice sent to the bank so valuation and bank cheque can be organised for next week. On the home stretch now! Re: Custom Build in Warrnambool 536Feb 01, 2017 8:52 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We have an occupancy certificate! Small hurdle though, the shed still isn't up. We have put walkthrough the house booked for 6pm this afternoon which is great. Shed should go up tomorrow, power in to it the day after and then it had to be conplianced. The big question now is what the bank valuer will do if he turns up while the shed isn't finished - are we likely to get our bank cheque through for Friday or held up... we are crossing our fingers the valuation will exceed the financed cost by enough that we will be ok despite the shed being unfinished, especially as blocks down from us 200m2 smaller than ours are transacting for only $5,000 less than we paid for ours. Either way the builder is happy for us to move our new furniture in over the weekend; and our insurance has put in writing that they will cover our contents as long as we have an occupancy certificate (which we do!) Our NBN router hasn't arrived yet, despite scheduled go-day of Friday. Probably cutting it a bit fine given I signed up around New Years.... hopefully it will arrive today or tomorrow. Re: Custom Build in Warrnambool 539Feb 01, 2017 9:56 am Just got an SMS from the bank saying they have processed the payment so I guess that means the valuation went off in our favour! Gotta call our broker now to see if there are any catches Re: Custom Build in Warrnambool 540Feb 01, 2017 3:10 pm Congrats silencer!!! So excited for you!!! When is your shed meant to be done? What's the hold up? GJ Gardner Modified Coolum 277 viewtopic.php?t=83643 I'd get the gutters to match your roof and pipes to match the paint - otherwise they become a feature. Nice pick with the paint colours! 1 35105 6 57396 Soak wells and electrical run in happening this week! Summit has told me they will relocate the laundry plumbing after the walls are completed. I'm actually pretty happy… 13 36904 |
