Browse Forums Building A New House Re: Things you forget - summary page 20 441Mar 29, 2012 8:34 pm I think double checking everything and not leaving anything to chance is the only way to go about anything these days, especially when it comes to your home. I have had the sinking feeling that maybe we have forgotten an important fitting such as a powerpoint in a room or a light fitting here and there and regretted that we didn't take the time to "check twice - cut once" This never happens now but a tough lesson learnt the hard way Dean Dean Cato - CEO Murano Italian Decor and Glass Lights http://www.italiandecor-glasslights.com salesandsupport@italiandecor-glasslights.com Things you forget - summary page 20 443Apr 03, 2012 12:47 pm PowerPoint up high on laundry wall for the dryer! We were so pleased with ourselves that we had put the extra brace in while the house was at frame stage so we could just put the dryer on the wall that it wasn't until the laundry had been installed that I realised we forgot the power point. Jasmin Hickinbotham Belmont - modified Signed: February 2011 Slab should go down before 2012 My build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=52310&p=799483#p799483 Re: Things you forget - summary page 20 444Apr 03, 2012 1:13 pm Make sure insulation and downlights are installed properly (and not allowing air to escape). My dad just pointed me to this recent radio broadcast which talks about losing 50% of insulation caused by just 5% gaps in insulation, by sub-standard builders. Here is a link to the story: http://www.abc.net.au/radionational/pro ... 01/3917618 SunshineT's Build: viewtopic.php?f=31&t=34585 Designs start: 4/12/09 DA: 5/7/11 Demo: 22/12/11 Slab: 24/2/12 Keys: 31/8/12 Re: Things you forget - summary page 20 445Apr 06, 2012 1:01 pm SunshineT Make sure insulation and downlights are installed properly (and not allowing air to escape). My dad just pointed me to this recent radio broadcast which talks about losing 50% of insulation caused by just 5% gaps in insulation, by sub-standard builders. Here is a link to the story: http://www.abc.net.au/radionational/pro ... 01/3917618 What you mentioned is EXACTLY what I read from other thread. The downlight was originally used for commercial premises If I use down lights, I'd have them in downstairs only. My home building https://forum.homeone.com.au/viewtopic.php?f=31&t=55844 Demolished: 11/May/12 Approval: 3/Jul/12 Concrete Slab: 20/Jul/12 Frame: 14/Aug/12 Handover: 21/DEC/12 Re: Things you forget - summary page 20 446Apr 17, 2012 2:24 pm The most important thing is mains gas to the outside BBQ we forgot this at selections but luckily I went past the house while the gas guy was installing the other connections and gave him cash so we now have mains gas for the BBQ!!! this is important folks. haha... Block settled - 08/08/2011 Site scraped - 09/12/2011 Slab - 19/01/2012 Frames - 13/02/2012 Roof - 01/03/2012 Bricks - 19/03/2012 Lock-up - 19/04/2012 Hand over - 05/06/2012 Re: Things you forget - summary page 20 447Apr 18, 2012 1:53 pm We had the tap provision - it only cost $120 ... so worth it ... love having cold water and ice at hand! For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Things you forget - summary page 20 448May 04, 2012 11:42 am Double check placement of GPOS, TV outlets, light location, gas negus location. Specify the location and HEIGHT of external light (sparkies will just wing it and next thing you know the light bayonets are so low than what you thought it would be.) We had a water tap and gas negus point installed at the back, since the symbols for the tap and negus point are quite big on the floor plan, the gas fitter fitted the negus point close to the room window and farther away from the alfresco (as shown on the plan). Now we need to have a longer hose for the barbi. Like i said, specify the location (have the draftsman put measurements in the plan so that the tradies would know where to put these points instead of winging it. Measurements llike how high off the ground/floor, distance from corners, etc. smorgzzz ItalianGlassDecor I think that the only thing that saves people from the little mistakes which are normally due to the hectic lifestyles we lead, is to sit down and go over and over plans with your partner in intricate detail until there simply isn't any chance of forgetting things. Easier said that done I know but this works for us Dean This is what we did, I'd look over it, he'd look over it, we'd look over it and repeat... I picked up things that he didn't think of, like adding a broom part to our laundry cupboard, there were only shelves, no room for ironing board, broom, mop! A simple variation that cost nothing to change, but peace of mind when you want a tidy home. Another thing my husband didn't pick up, our laundry door opened up onto our laundry cupboard, so to access the cupboard, you'd have to shut yourself into the laundry. We have had this changed to a cavity slider, with a lovely translucent door. I also find this more practical being a cat owner and having a litter tray in the laundry, you can have the sliding door ajar without everyone being able to see the litter tray, but the cat can come and go as he pleases. (Can you tell, the cat rules the house!) Prelim Contract to Build - 31/07/2011 Building contract and Plans - 21 Sept 2011 Pre-start - 13 Oct 2011 Settlement - 14 Oct 2011 Earthworks - 5 Dec 2011 SLABBED - 13 Dec 2011 Roof Framed -7 Mar12 Re: Things you forget - summary page 20 449May 04, 2012 12:05 pm aries24 Double check placement of GPOS, TV outlets, light location, gas negus location. Specify the location and HEIGHT of external light (sparkies will just wing it and next thing you know the light bayonets are so low than what you thought it would be.) We had a water tap and gas negus point installed at the back, since the symbols for the tap and negus point are quite big on the floor plan, the gas fitter fitted the negus point close to the room window and farther away from the alfresco (as shown on the plan). Now we need to have a longer hose for the barbi. Like i said, specify the location (have the draftsman put measurements in the plan so that the tradies would know where to put these points instead of winging it. Measurements llike how high off the ground/floor, distance from corners, etc. Thank you for the great tips. As they say, never assume. Check and double check for REAL measurement values. Re: Things you forget - summary page 20 450May 04, 2012 1:13 pm Really have them put measurements as to where these items would be installed. we even had a light switch installed behind the linen door!!! Vatche aries24 Double check placement of GPOS, TV outlets, light location, gas negus location. Specify the location and HEIGHT of external light (sparkies will just wing it and next thing you know the light bayonets are so low than what you thought it would be.) We had a water tap and gas negus point installed at the back, since the symbols for the tap and negus point are quite big on the floor plan, the gas fitter fitted the negus point close to the room window and farther away from the alfresco (as shown on the plan). Now we need to have a longer hose for the barbi. Like i said, specify the location (have the draftsman put measurements in the plan so that the tradies would know where to put these points instead of winging it. Measurements llike how high off the ground/floor, distance from corners, etc. Thank you for the great tips. As they say, never assume. Check and double check for REAL measurement values. Prelim Contract to Build - 31/07/2011 Building contract and Plans - 21 Sept 2011 Pre-start - 13 Oct 2011 Settlement - 14 Oct 2011 Earthworks - 5 Dec 2011 SLABBED - 13 Dec 2011 Roof Framed -7 Mar12 Re: Things you forget - summary page 20 451May 04, 2012 1:45 pm SunshineT Make sure insulation and downlights are installed properly (and not allowing air to escape). My dad just pointed me to this recent radio broadcast which talks about losing 50% of insulation caused by just 5% gaps in insulation, by sub-standard builders. Here is a link to the story: http://www.abc.net.au/radionational/pro ... 01/3917618 On this note I'd say re-consider your need for downlight's completely. The "gaps" are required for fire safety, even if you have a more expensive fire-safe downlight you still need an insulation gap, its just a smaller insulation gap. This article (which is a multi-page article, this link is just to the results): http://www.consumer.org.nz/reports/rece ... st-results Determined how much heat loss from having downlight's installed, there is also the fact that you need more lights and therefore spend more on lighting itself when the lights are on. I was more worried about heat loss as that can be a large cost In regard to external taps. Having one in the alfresco is great, but also consider having one on the opposite side of the house for watering the garden. Finally, in regard to external lighting do consider if you want lights on the outside of your garage / pillars outside the house. Or considering getting capped end-points fitted. Re: Things you forget - summary page 20 452May 05, 2012 2:03 pm aries24 Double check placement of GPOS, TV outlets, light location, gas negus location. Specify the location and HEIGHT of external light (sparkies will just wing it and next thing you know the light bayonets are so low than what you thought it would be.) We had a water tap and gas negus point installed at the back, since the symbols for the tap and negus point are quite big on the floor plan, the gas fitter fitted the negus point close to the room window and farther away from the alfresco (as shown on the plan). Now we need to have a longer hose for the barbi. Like i said, specify the location (have the draftsman put measurements in the plan so that the tradies would know where to put these points instead of winging it. Measurements llike how high off the ground/floor, distance from corners, etc. the problem is when you have one trade set the height say 200mm AFL (Above Floor Level) then all other trades that come in they need to match... 200mm is very low .. 300mm and above is best.. (for all your outlets) for light switches i thinnk they are all roughly at 1100mm i thik there is a national standard they are following Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Things you forget - summary page 20 453May 07, 2012 12:19 am hi guys, have read 5 pages of this thread and already have a list as long as my arm, this thread is costly to the budget! 1 thing i didnt see in my 5 pages was a rear roller door on your garasge if your house design permits, we are putting one in, especially on skinny blocks this could be the only access to to the rear of your block for trailer/ride on mower / boat etc. Things you forget - summary page 20 454May 07, 2012 7:46 am So embarrassing but.... Power point for the washing machine! We moved our taps for the machine and forgot to move the power point :O Sent from my iPhone so please excuse my spelling mist cakes Building the Drysdale 30 Wallara Waters, Wallan My Blog : http://www.ourwallanhome.blogspot.com My thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=50975 Re: Things you forget - summary page 20 455May 07, 2012 7:49 am maxlucy1 hi guys, have read 5 pages of this thread and already have a list as long as my arm, this thread is costly to the budget! 1 thing i didnt see in my 5 pages was a rear roller door on your garasge if your house design permits, we are putting one in, especially on skinny blocks this could be the only access to to the rear of your block for trailer/ride on mower / boat etc. Did you read the summary? That's the most important part Quote: Structural: • Warranty if you install things yourself (ie you put tiles down and later slab cracks, who will replace the tiles) • Be aware of the INTERNAL dimensions of your garage. Can you park a 4WD drive in there WITH a tow bar fitted? • Rear garage roller door - allows incredible access (Double-hinge doors may be an even better option) Re: Things you forget - summary page 20 457May 07, 2012 8:51 am ha ha. see in the subject line. things you forget - summary page 20. that is the clue. cattycatcat...eeek. did you have to get the sparky back? or what happened Re: Things you forget - summary page 20 459May 07, 2012 10:29 am that's ok, you got the dumb today mate!! Things you forget - summary page 20 460May 08, 2012 8:08 am Kiwi - my brother is a sparky so did it for us for nothing. Sent from my iPhone so please excuse my spelling mist cakes Building the Drysdale 30 Wallara Waters, Wallan My Blog : http://www.ourwallanhome.blogspot.com My thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=50975 Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 12447 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 7236 A question. Im in Queensland and building a new home. We managed to reach practical completion 6 weeks ago but we haven't heard any date for handover yet. Who should we… 0 6277 |
