Browse Forums Building A New House Re: Building the Sahara Q3 with Henley 421Mar 30, 2015 6:40 pm Found a discrepancy between contract and final drawings today . the butlers pantry and powder room doors are 720mm in the drawings but 820mm in the contract. One more thing to bring up with admin. But bigger concern is the water point as I'm afraid it will block the pantry door. I think we'll have to get this done now Building the Sahara Q3 with Henley Re: Building the Sahara Q3 with Henley 422Mar 30, 2015 6:40 pm Ilaeria Awesome! What colour is your roof Izzyb? Building the Sahara Q3 with Henley Re: Building the Sahara Q3 with Henley 423Mar 30, 2015 6:43 pm Izzyb Ilaeria Awesome! What colour is your roof Izzyb? Building the Sahara Q3 with Henley Ah cool that's what we're getting too, looks great! Shame about the water point, is it a building code requirement or something that it can't be recessed like we can do here in QLD? Jen (& Dave) Plantation Bronte, Ormeau Ridge, Gold Coast QLD 12/03/2015 - Commencement... 26/08/2015 - Handover! viewtopic.php?f=31&t=76446 Re: Building the Sahara Q3 with Henley 424Mar 30, 2015 7:34 pm It's looks great Izzyb. Roof is on already. Do you want wider doors there? Re: Building the Sahara Q3 with Henley 425Mar 30, 2015 8:25 pm Ours contract says 'up to 820mm' and the drawings are 720mm too. Mmmmm Re: Building the Sahara Q3 with Henley 426Mar 30, 2015 11:16 pm Izzyb Just wondering because the sarking appears to be in direct contact with the colourbond roof won't the condensation just pass through it? Should there be room in between the sarking and the colourbond roof so there is no contact point? Similar to how insulation in the external walls shouldn't be in contact with the foil wrap as well to prevent moisture transfer and hence mould? Isn't that why insulation is installed with strings to hold it back so it doesn't contact the external layer? Re: Building the Sahara Q3 with Henley 427Mar 31, 2015 2:24 am Kathyclaude2006 Ours contract says 'up to 820mm' and the drawings are 720mm too. Mmmmm Building the Sahara Q3 with Henley Re: Building the Sahara Q3 with Henley 428Mar 31, 2015 2:25 am siapao Izzyb Just wondering because the sarking appears to be in direct contact with the colourbond roof won't the condensation just pass through it? Should there be room in between the sarking and the colourbond roof so there is no contact point? Similar to how insulation in the external walls shouldn't be in contact with the foil wrap as well to prevent moisture transfer and hence mould? Isn't that why insulation is installed with strings to hold it back so it doesn't contact the external layer? Building the Sahara Q3 with Henley Re: Building the Sahara Q3 with Henley 429Mar 31, 2015 2:28 am Ilaeria Izzyb Ilaeria Awesome! What colour is your roof Izzyb? Building the Sahara Q3 with Henley Ah cool that's what we're getting too, looks great! Shame about the water point, is it a building code requirement or something that it can't be recessed like we can do here in QLD? Building the Sahara Q3 with Henley Re: Building the Sahara Q3 with Henley 430Mar 31, 2015 2:29 am mirz It's looks great Izzyb. Roof is on already. Do you want wider doors there? Building the Sahara Q3 with Henley Re: Building the Sahara Q3 with Henley 431Mar 31, 2015 3:11 am siapao Izzyb Just wondering because the sarking appears to be in direct contact with the colourbond roof won't the condensation just pass through it? Should there be room in between the sarking and the colourbond roof so there is no contact point? Similar to how insulation in the external walls shouldn't be in contact with the foil wrap as well to prevent moisture transfer and hence mould? Isn't that why insulation is installed with strings to hold it back so it doesn't contact the external layer? Building the Sahara Q3 with Henley Re: Building the Sahara Q3 with Henley 432Mar 31, 2015 5:46 am Izzyb siapao Izzyb Just wondering because the sarking appears to be in direct contact with the colourbond roof won't the condensation just pass through it? Should there be room in between the sarking and the colourbond roof so there is no contact point? Similar to how insulation in the external walls shouldn't be in contact with the foil wrap as well to prevent moisture transfer and hence mould? Isn't that why insulation is installed with strings to hold it back so it doesn't contact the external layer? Building the Sahara Q3 with Henley Interesting. Purely my opinion but i would have thought sarking installed over roof frame then metal roof beams than roof would be a better way to install it. But then again i have nothing to back this up and looking up bluescope steel website didn't find anything clear cut. I presume Henley know what they're doing though. Apart from nice roof and fast progress! Curious to know peoples opinion on light coloured roofs? Meant to be better from a heating/cooling aspect. Aesthetically nice and clean look i think but obviously subject to personal taste. Would it affect how much you would pay for a house? Re: Building the Sahara Q3 with Henley 433Mar 31, 2015 8:48 am Yea our sarking is installed exactly like yours so I think we both should be ok... Re: Building the Sahara Q3 with Henley 434Mar 31, 2015 9:57 pm siapao Izzyb siapao Just wondering because the sarking appears to be in direct contact with the colourbond roof won't the condensation just pass through it? Should there be room in between the sarking and the colourbond roof so there is no contact point? Similar to how insulation in the external walls shouldn't be in contact with the foil wrap as well to prevent moisture transfer and hence mould? Isn't that why insulation is installed with strings to hold it back so it doesn't contact the external layer? Building the Sahara Q3 with Henley Interesting. Purely my opinion but i would have thought sarking installed over roof frame then metal roof beams than roof would be a better way to install it. But then again i have nothing to back this up and looking up bluescope steel website didn't find anything clear cut. I presume Henley know what they're doing though. Apart from nice roof and fast progress! Curious to know peoples opinion on light coloured roofs? Meant to be better from a heating/cooling aspect. Aesthetically nice and clean look i think but obviously subject to personal taste. Would it affect how much you would pay for a house?[/quote] I don't think Colour affects the price for colorbond unless If the colour you are after is not in their standard range maybe. Building the Sahara Q3 with Henley Re: Building the Sahara Q3 with Henley 435Apr 01, 2015 7:37 pm Evap cooling installed Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ and ducting Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ return air hole in the corner of powder room Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building the Sahara Q3 with Henley Re: Building the Sahara Q3 with Henley 436Apr 01, 2015 7:41 pm Raised this water point in fridge cavity with SS Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ this will make my fridge go over the left side of the pantry door. SS said : "Hi , that is a temp fitting on fridge water point, we supply a chrome tap outlet, that sits approx 30mm out from plaster. This is done with Plumbing fit off down the track. We don't recess them into walls. " Building the Sahara Q3 with Henley Re: Building the Sahara Q3 with Henley 437Apr 01, 2015 7:46 pm So my fridge will still be outside the cavity but right before the pantry door Building the Sahara Q3 with Henley Building the Sahara Q3 with Henley 438Apr 01, 2015 8:20 pm Can you ask SS to move cold water point in butler pantry? This will save you from any future grief of fridge sizes. It would be heaps more than 30mm at the end with final tap. See photo in my thread. Re: Building the Sahara Q3 with Henley 439Apr 02, 2015 11:06 am mirz Can you ask SS to move cold water point in butler pantry? This will save you from any future grief of fridge sizes. It would be heaps more than 30mm at the end with final tap. See photo in my thread. Building the Sahara Q3 with Henley Re: Building the Sahara Q3 with Henley 440Apr 02, 2015 12:31 pm moving this tap to pantry is no biggy before plaster will go up. if you want to get this done, be pushy. we are lucky to have water point in pantry otherwise it was going to be a nightmare. Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that… 1 12644 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11755 |
