Correct, only one switch will connect to the router even 30 switches are installed. Other switches will connect to each other.
Sorry I am not sure what you mean by own hardware ?
Do you use standard ESP8266 switches?
Browse Forums Building A New House Re: Future proofing your home with Smart Lighting Control 41Sep 02, 2020 12:00 pm CTEC Smart Homes alexp79 Does it mean that switches link themselves into a separate Wi-Fi Mesh network? Cool. Do you use your own hardware for that? Correct, only one switch will connect to the router even 30 switches are installed. Other switches will connect to each other. Sorry I am not sure what you mean by own hardware ? Do you use standard ESP8266 switches? Re: Future proofing your home with Smart Lighting Control 42Sep 02, 2020 12:03 pm alexp79 CTEC Smart Homes alexp79 Does it mean that switches link themselves into a separate Wi-Fi Mesh network? Cool. Do you use your own hardware for that? Correct, only one switch will connect to the router even 30 switches are installed. Other switches will connect to each other. Sorry I am not sure what you mean by own hardware ? Do you use standard ESP8266 switches? No, we don't use ESP8266. This new range will support Home Assistant directly without being flashed. Visit www.ctec.com.au for all your smart lighting needs. Re: Future proofing your home with Smart Lighting Control 43Sep 02, 2020 12:05 pm CTEC Smart Homes alexp79 Do you use standard ESP8266 switches? No, we don't use ESP8266. This new range will support Home Assistant directly without being flashed. Can you provide cost estimate range of how much it will generally cost e.g. on typical 30 switches set up? Just for reference purposes. You use your own electrician to install switches, correct? Re: Future proofing your home with Smart Lighting Control 44Sep 02, 2020 12:09 pm alexp79 CTEC Smart Homes alexp79 Do you use standard ESP8266 switches? No, we don't use ESP8266. This new range will support Home Assistant directly without being flashed. Can you provide cost estimate range of how much it will generally cost e.g. on typical 30 switches set up? Just for reference purposes. You use your own electrician to install switches, correct? Roughly $4500-4800 for 30 switches, please send us an email via our website www.ctec.com.au and someone will get back to you with a quote. We don't have our own electricians but we can help you find electrician in your local area or you can use your own electrician. Also let you know the new product supports Apple HomeKit as well. Thanks Visit www.ctec.com.au for all your smart lighting needs. Re: Future proofing your home with Smart Lighting Control 45Sep 03, 2020 3:29 pm CTEC Smart Homes Blacktea2sugars CTEC Smart Homes Thanks for asking. It depends on where you location is. If you are in WA, its likely not as having neutral wire in WA is not a common practise. In other states it possibly yes, but still it depends on how the house was built. The best way is to confirm with your electrician or builder. Thank you I have my electrical appointment in 2 weeks. do I simply ask if switches have a neutral wire? I don't want to engage in "upgrade chit chat" at this elec meeting, as I KNOW they will try and upsell me their system. Thanks for your comment. You can simply ask if they are going to run neutral wires at each light switches. It pretty standard to have neutral wires in new houses these days and if not, the extra cost shouldn't be much. expecting few hundred dollars. Hope you will get into smart home space shortly Just reaching out to see if you did get Neutral for your switches as mentioned and if yes then how much did the builder charge extra for that ? Thanks Re: Future proofing your home with Smart Lighting Control 46Sep 04, 2020 11:34 am Ozshaz CTEC Smart Homes Blacktea2sugars I have my electrical appointment in 2 weeks. do I simply ask if switches have a neutral wire? I don't want to engage in "upgrade chit chat" at this elec meeting, as I KNOW they will try and upsell me their system. Thanks for your comment. You can simply ask if they are going to run neutral wires at each light switches. It pretty standard to have neutral wires in new houses these days and if not, the extra cost shouldn't be much. expecting few hundred dollars. Hope you will get into smart home space shortly Just reaching out to see if you did get Neutral for your switches as mentioned and if yes then how much did the builder charge extra for that ? Thanks the cost of including neutral wires shouldn't be to high. Most of new houses have neutral wires these days. Better to confirm with your builder or electrician Visit www.ctec.com.au for all your smart lighting needs. Re: Future proofing your home with Smart Lighting Control 47Sep 14, 2020 11:22 am Another project is done is Melbourne . Ctec smart light switches are fully installed through out this house. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Visit www.ctec.com.au for all your smart lighting needs. Re: Future proofing your home with Smart Lighting Control 49Sep 14, 2020 1:35 pm alexp79 Hi CTEC, I wonder if your switches allow the configuration for the level of glow at night? e.g. I don't want some of my switches to glow brightly. Hi Alex The LED light on the panel can be turned off via the app. even you can schedule it for example turn the background light off from 10 pm to 7 am. All the setup is in the app. See following video from 3:05s Thanks Visit www.ctec.com.au for all your smart lighting needs. Re: Smart light switch - Something you should have 50Sep 17, 2020 10:30 am Visit www.ctec.com.au for all your smart lighting needs. Re: Smart light switch - Something you should have 51Sep 22, 2020 8:08 pm Product video for our new range. Visit www.ctec.com.au for all your smart lighting needs. Re: Smart light switch - Something you should have 53Sep 22, 2020 9:12 pm alexp79 is this the one which comes with wifi mesh? Hi Alex Yes it's mesh WiFi smart light switch Visit www.ctec.com.au for all your smart lighting needs. Re: Smart light switch - Something you should have 54Sep 26, 2020 6:20 pm Any Apple HomeKit users? We have a present for you. Our new range works with HomeKit Visit www.ctec.com.au for all your smart lighting needs. Re: Smart light switch - Something you should have 56Sep 26, 2020 6:58 pm alexp79 How many gangs max you can have on one switch from your new range? Also, are smart dimmers supported from the same switches? Hi Alex The maximum is still 3 gang, There is another switch which is a single gang dimmer Visit www.ctec.com.au for all your smart lighting needs. Re: Smart light switch - Something you should have 57Oct 02, 2020 4:23 pm Visit www.ctec.com.au for all your smart lighting needs. Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1905 I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag. 4 16375 Hi Everyone I learned something this week that I thought would be worth sharing. In NSW a lot of developers of subdivisions put covenants on the land which normally… 0 6930 |
