Browse Forums Building A New House Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 41Jul 20, 2018 9:43 pm Jeez Salfield, I don’t know what to say. That’s really disappointing and clearly very stressful for you. I have my fingers crossed they can sort this out for you guys. Building the Rawson Edge 39 MKI - https://forum.homeone.com.au/viewtopic.php?f=31&t=89729&p=1756917#p1756917 Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 42Jul 20, 2018 10:11 pm KateAndDuke Jeez Salfield, I don’t know what to say. That’s really disappointing and clearly very stressful for you. I have my fingers crossed they can sort this out for you guys. Thank you. Losing our minds unfortunately. The lack of urgency has been really disappointing. Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 43Jul 23, 2018 6:20 pm Update. Unfortunately it’s just worse and worse. All I can say is never ever trust anything that any builder or any of there staff say regardless of how nice a person they may be. To anybody on here that I recommended Rawson too I am sorry. If you get a tender read it back to front, especially the generic stuff that doesn’t even seem to apply to your build as they will use it against you. We received a call from the GM today and long story short he stated that he can’t work out why Rawson are/were building our house they way they are. We now have to have all new plans drawn up and from what we discovered the staff we trusted at Newcastle essentially don’t know what they are doing. So we are still no closer to building this thing and if we could get our money back we would just pull out. Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 44Jul 23, 2018 6:42 pm Another thing for anyone interested. A lot if not all builders send your plans offshore to be drawn up to countries that wouldn’t know 💩 about our regulations etc 😳😳 Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 45Jul 31, 2018 5:43 pm Another update but a happier one hopefully. Rawsons GM has come through. Why it wasn’t this way in the first place. Less cut and fill. One more step in the garage and two less in the house which is ideal. The big issue with the retaining is also sorted with wall being reduced to only a meter high. Still engineered but much better than 1.4 or even two walls. The plan needs to be corrected as it still says 3 steps in the house but clearly it’s one. 😁 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 46Jul 31, 2018 7:55 pm Salfield Another update but a happier one hopefully. Rawsons GM has come through. Why it wasn’t this way in the first place. Less cut and fill. One more step in the garage and two less in the house which is ideal. The big issue with the retaining is also sorted with wall being reduced to only a meter high. Still engineered but much better than 1.4 or even two walls. The plan needs to be corrected as it still says 3 steps in the house but clearly it’s one. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ So good to hear that it’s worked out to your satisfaction - albeit with a few stressful moments on the way. Building the Rawson Edge 39 MKI - https://forum.homeone.com.au/viewtopic.php?f=31&t=89729&p=1756917#p1756917 Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 47Jul 31, 2018 8:04 pm KateAndDuke Salfield Another update but a happier one hopefully. Rawsons GM has come through. Why it wasn’t this way in the first place. Less cut and fill. One more step in the garage and two less in the house which is ideal. The big issue with the retaining is also sorted with wall being reduced to only a meter high. Still engineered but much better than 1.4 or even two walls. The plan needs to be corrected as it still says 3 steps in the house but clearly it’s one. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ So good to hear that it’s worked out to your satisfaction - albeit with a few stressful moments on the way. Cheers guys. Thanks for your support. 🍺 Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 48Aug 03, 2018 7:04 pm Hi Salfield, just wanted to put up a quick post to say thanks for your awesome thread and I hope that Rawson are working things out. Great to read about someone else who is building a Chifley 42, we just settled on a KDR block in Baulkham Hills but had a long-ish settlement so have been talking to Rawson since a few weeks before we found the block. We had our tender presentation on the 5th July and signed it off but only settled on the block on the 19th July Got the Plan Presentation coming up on the 16th August and really struggling to decide on all our external colours, etc. For some reason I had it in my mind that we'd tell Rawson the few different options we were thinking and they'd be able to show us a 3D rendered mock up of the Chifley with the different brick, guttering, roof tile, etc options before we made the final decision. Didn't realise it really is a case of having to look at all the things separately and just hope that what we pick works when all put together, very daunting. Did you use any sort of 3D modelling yourself or any other good way of making sure what you were picking would all work together? Haven't talked about things like what sort of home theatre setup we want yet so assume that is done at the internal / electrical appointments. I'm wondering as well what things will be cheaper to do through other contractors (eg. demolition, landscaping, home theatre, lights, etc) as surely Rawson have a pretty hefty margin on these things. I will have to start a thread up for our build to show plans, etc as we have done quite a lot of modification to get exactly what we want which others might find interesting as I think the more info up here the better, it's crazy how much you don't think about until after something is built so really want to make sure we get it right. Build Thread: Building a Rawson Chifley 42 in Baulkham Hills NSW All progress photos on Google Photos: HERE Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 49Aug 03, 2018 9:03 pm JiMb00 Hi Salfield, just wanted to put up a quick post to say thanks for your awesome thread and I hope that Rawson are working things out. Great to read about someone else who is building a Chifley 42, we just settled on a KDR block in Baulkham Hills but had a long-ish settlement so have been talking to Rawson since a few weeks before we found the block. We had our tender presentation on the 5th July and signed it off but only settled on the block on the 19th July Got the Plan Presentation coming up on the 16th August and really struggling to decide on all our external colours, etc. For some reason I had it in my mind that we'd tell Rawson the few different options we were thinking and they'd be able to show us a 3D rendered mock up of the Chifley with the different brick, guttering, roof tile, etc options before we made the final decision. Didn't realise it really is a case of having to look at all the things separately and just hope that what we pick works when all put together, very daunting. Did you use any sort of 3D modelling yourself or any other good way of making sure what you were picking would all work together? Haven't talked about things like what sort of home theatre setup we want yet so assume that is done at the internal / electrical appointments. I'm wondering as well what things will be cheaper to do through other contractors (eg. demolition, landscaping, home theatre, lights, etc) as surely Rawson have a pretty hefty margin on these things. I will have to start a thread up for our build to show plans, etc as we have done quite a lot of modification to get exactly what we want which others might find interesting as I think the more info up here the better, it's crazy how much you don't think about until after something is built so really want to make sure we get it right. Hey mate, I won’t speak for Simon but I can answer some of your queries based on our experiences with Rawson too. We are building the Edge. You really need to decide on most of your colours prior to the internal and electrical appointment. We did a lot of research on bricks, roof colours, kitchen colour combos and tiles. If your plan presentation is at the same place as the selection centre, go for a browse after. Make an appointment at Tile Direct (if that’s the supplier in Sydney) to have a pre-selection look. We used Sketch Up to help draw up the kitchen in particular to help visualise. I also used Photoshop to try and replicate our chosen colours on the facade of the house using the computer graphic image on the Rawson website (see below). I think we chose internal paint colours, carpet and minor fixtures (i.e. door handles) on the day of the appointment. But everything else we had a good idea of first. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Rawson won’t run through a 3D render with you. There’s just no time for it unfortunately. Some other thoughts below: Home theatre: Rawson use the Lifestyle Store and I would highly recommend them. Go in and have a chat with them about what you want and they can tell you want you need to include in your electrical appointment. Lighting: Rawson do charge a lot for lighting. $150ish for a downlight from memory. We had them include provisions (i.e. wiring) for future downlights which is much cheaper and sought to buy our own downlights. Same with fans. It worked out cheaper (and better quality products) but required a bit of stuffing around. Also you need to have an idea of your lighting plan prior to the electrical appointment. We found that Beacon will help you through the number and separation of lights if you take your plans into a shop! I would suspect demolition and landscaping would be best done by other contractors, but others can advise on that. Good luck. And yes, please start a thread Building the Rawson Edge 39 MKI - https://forum.homeone.com.au/viewtopic.php?f=31&t=89729&p=1756917#p1756917 Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 50Aug 03, 2018 9:50 pm JiMb00 Hi Salfield, just wanted to put up a quick post to say thanks for your awesome thread and I hope that Rawson are working things out. Great to read about someone else who is building a Chifley 42, we just settled on a KDR block in Baulkham Hills but had a long-ish settlement so have been talking to Rawson since a few weeks before we found the block. We had our tender presentation on the 5th July and signed it off but only settled on the block on the 19th July Got the Plan Presentation coming up on the 16th August and really struggling to decide on all our external colours, etc. For some reason I had it in my mind that we'd tell Rawson the few different options we were thinking and they'd be able to show us a 3D rendered mock up of the Chifley with the different brick, guttering, roof tile, etc options before we made the final decision. Didn't realise it really is a case of having to look at all the things separately and just hope that what we pick works when all put together, very daunting. Did you use any sort of 3D modelling yourself or any other good way of making sure what you were picking would all work together? Haven't talked about things like what sort of home theatre setup we want yet so assume that is done at the internal / electrical appointments. I'm wondering as well what things will be cheaper to do through other contractors (eg. demolition, landscaping, home theatre, lights, etc) as surely Rawson have a pretty hefty margin on these things. I will have to start a thread up for our build to show plans, etc as we have done quite a lot of modification to get exactly what we want which others might find interesting as I think the more info up here the better, it's crazy how much you don't think about until after something is built so really want to make sure we get it right. Pleasure Jim. Congrats on the build. This site has been great to help us along the way. . An update for us is, Rawson have come through and we should have our approval, CDC Wise, on Monday. The way it was looking we never thought we would get there. But as usual, one step forward one step back. Because we had to delay our demo people they now say they can’t do it. 😡😡 Now we have to find a demo company that is not booked solid. So if we can knock down soon, kick off should be in 4 to 6 weeks. . Anyway to answer some of your questions. I tried mucking around with some 3D apps but ended up giving up. Essentially we went to a heap of display homes, not just Rawson homes, all of them and got an idea on styles and colours we liked. once you have an idea, you should be ok. Julie at Rawson in Newcastle was fantastic When we did selections, so hopefully you get a similar experience. Julie made suggestions and didn’t just let us pick silly stuff not that we would have but you get the picture. It’s still daunting and we found the tile selections the hardest. Like you say you just have to hope they go together, but again they were very helpful. Now home theatre is NOT done at electrical. You will need to go to the lifestyle store to organise that prior to electrical as they will give you a break down of the stuff they need Rawson to install, such as data points, prior to them doing there stuff. The lifestyle store are the only trades they will allow on site during the build that aren’t directly from Rawson. This would be different if you are doing a lot of stuff after handover, which brings me to your cost question. From what I have researched the price difference between getting someone in after handover and what Rawson charge is relatively minimal. You also need to consider that, if Rawson do it it will be covered by there build warranty, but if not it won’t. If I was a sparky by trade I might do it myself but otherwise we are going with Rawson. Landscaping is different, we will get someone else to do that. Rawson as a 20% builders margin. But for example, we have upgraded to a Bosch dishwasher. Rawsons price even with margin was cheaper than in the store due to rawsons buying power. Rawson no longer do demo. Well that’s what they told us. We had to get our own, so from experience start finding someone now as they are booked out solid for months and quotes can be massively different. Good luck mate, any other questions let me know. It’s a bloody stressful experience, but then we have had dramas, so I hope you don’t have the same. Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 51Aug 10, 2018 7:50 pm Hi KateAndDuke & Salfield, thanks for your replies & great info. I've popped up my build thread now if you're interested in checking it out - viewtopic.php?f=31&t=92920 Build Thread: Building a Rawson Chifley 42 in Baulkham Hills NSW All progress photos on Google Photos: HERE Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 52Aug 10, 2018 7:59 pm JiMb00 Hi KateAndDuke & Salfield, thanks for your replies & great info. I've popped up my build thread now if you're interested in checking it out - viewtopic.php?f=31&t=92920 Nice work mate. I’ll check it out. Hope your having more joy than us. 🍺 Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 54Aug 17, 2018 8:09 pm Little update for us.. Our old house is gone. 🥂😁. Big thanks to our demo company, Terrain Earthworks. http://terrainearthworks.com.au/ Thankfully Matt from terrain was able to step in after our other demo company Watson demolition did the dirty on us and left us in the lurch. A blessing in disguise it seems. Anyone in the Newcastle area looking to demo, I thoroughly recommend them. Now we wait for Rawson to get on site. 6 weeks at best we are told which is very disappointing. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 55Aug 17, 2018 9:01 pm Salfield Little update for us.. Our old house is gone. 🥂. Big thanks to our demo company, Terrain Earthworks. http://terrainearthworks.com.au/ Thankfully Matt from terrain was able to step in after our other demo company Watson demolition did the dirty on us and left us in the lurch. A blessing in disguise it seems. Anyone in the Newcastle area looking to demo, I thoroughly recommend them. Now we wait for Rawson to get on site. 6 weeks at best we are told which is very disappointing. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Woohoo! 🥂 progress! Building the Rawson Edge 39 MKI - https://forum.homeone.com.au/viewtopic.php?f=31&t=89729&p=1756917#p1756917 Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 56Aug 17, 2018 9:38 pm KateAndDuke Salfield Little update for us.. Our old house is gone. 🥂. Big thanks to our demo company, Terrain Earthworks. http://terrainearthworks.com.au/ Thankfully Matt from terrain was able to step in after our other demo company Watson demolition did the dirty on us and left us in the lurch. A blessing in disguise it seems. Anyone in the Newcastle area looking to demo, I thoroughly recommend them. Now we wait for Rawson to get on site. 6 weeks at best we are told which is very disappointing. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Woohoo! 🥂 progress! Some serious stress relief to see it moving ahead. 😁🍺🍺🥂🥂 Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 57Oct 03, 2018 10:31 pm Ok quick update. Rawson were due to take control of our site last Monday but nothing seem to indicate that that happened. Anyway I drove past the site today and some surveyors were there. Anyone know what these pegs are indicating? They are placed on the boundaries on both sides front and back but seem to be just in the building envelope. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And this is our site currently. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 58Oct 04, 2018 2:17 pm I think they're used to mark out the build area, like how far back they'll scrape/cut/fill. Exciting times ahead! Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 59Oct 04, 2018 2:19 pm CG Scardycat I think they're used to mark out the build area, like how far back they'll scrape/cut/fill. Exciting times ahead! Thanks for that. I hope so. We were hoping they would go to the fence but weren’t sure. Re: KDR - Rawson Chifley 42 mark ii in Newcastle. 60Oct 18, 2018 1:12 pm Always get multiple quotes, no matter how reasonable/cheap you think it is. I remember getting a few quotes for a pool fence, roughly around the same price, thinking the… 5 9977 I have a Nectre Mk2 wood fire recently installed, the flue rises approx 700mm before entering an existing brick chimney via a 45 degree elbow with approx 400mm connection… 0 2285 Just started the Build process for Chifley 42 with Rawson homes, will keep you all posted with the Build progress. 0 3554 |
