If you're building the same house as me I have a few tips for electricals
- If you get IXL units which have exhaust fans they move the existing exhaust fans anywhere you like for free(have to pay for IXL though).
- get an external power point where your outdoor area will be and consider a gas point for heating too.
- if you want a greywater system you need to get them to make the pipes available, and get power point for pump
- get a point in the garage
- think about where you usually enter the house and put a light switch there. It doesn't show properly but I moved the double switch for the kitchen and meals to the thermostat(th in circle next to pantry)
- extra power points and TV point in master bedroom
- if you want downlights it's cheaper to do them after handover, same goes for evap cooling.
- you can order the flyscreens direct from ecoclassic(make the windows), they will have you house plan on file.
- return air vent might be best in hallway. they will redesign the WIP if you want this
Best of luck igfragalot99. Cheers,
Trepidman
