Browse Forums Building A New House Re: Kelsey78’s First Home in Honeywood DAH Build- Kitchen Dr 381Dec 04, 2014 4:33 pm Does it have to be 111mm from the back wall and the side wall or just the side wall? What about moving it to under the window? My build: viewtopic.php?f=31&t=68002 Re: Kelsey78’s First Home in Honeywood DAH Build- Kitchen Dr 382Dec 04, 2014 4:40 pm Burnsfirsttime What a stuff up!! I can't believe it got through council approval and everything else to this stage and only now it's being picked up??!!?? How about swopping your fridge and your oven/cooktop around? So your oven is next to your microwave? Would that work? I really think it is up to DAH to come up with a suitable solution rather than suggesting a smaller cooktop Swapping it may be a difficult option as the gas point will need to be moved. i'm pretty sure that's in the slab (well there's something covered by a cap which i assumed was the gas ) also, they will have to get a plumber back in to move the water for the fridge. Why does this have to be so hard this late in the game there are no real options! its just making do! Burnsfirsttime Does it have to be 111mm from the back wall and the side wall or just the side wall? What about moving it to under the window? It's 111mm from the side of the wall I believe. I can't move it under the window was the rangehood needs to be mounted on a wall. Dale Alcock Build in Honeywood Our Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70204&p=1154102#p1154102 Kelsey78’s First Home in Honeywood DAH Build- Kitchen Drama 383Dec 04, 2014 4:44 pm What a pity! If you think it would still be nice on other bench against window maybe you can suggest that and they fork out for the reinforced glass or whatever it is you need behind a cooker? I think it would be nice there. Stare out window whilst cooking... And have room either side of stove top for prepping work etc? Not as cramped as where it is now perhaps? Or does it muck up your underneath cupboard arrangements too much? Re: Kelsey78’s First Home in Honeywood DAH Build- Kitchen Dr 384Dec 04, 2014 4:50 pm Beazley77 What a pity! If you think it would still be nice on other bench against window maybe you can suggest that and they fork out for the reinforced glass or whatever it is you need behind a cooker? I think it would be nice there. Stare out window whilst cooking... And have room either side of stove top for prepping work etc? Not as cramped as where it is now perhaps? Or does it muck up your underneath cupboard arrangements too much? Thanks Beazley. That’s how we originally wanted it but as you said it mucked up the cupboards. Essentially we only had corner cupboard space to utilise for dishes and pots. That was the only reason why we changed it! oh how I wish I could change it back now. The problem with doing it now is there is nowhere to mount the rangehood. So unless they want to replace the windows it can’t be an option. If they do offer that then I’m back to the struggle with no storage! Dale Alcock Build in Honeywood Our Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70204&p=1154102#p1154102 Re: Kelsey78’s First Home in Honeywood DAH Build- Kitchen Dr 385Dec 04, 2014 5:49 pm Moving the wall would be my preference too Kelsey, provided you can still easily open the refrigerator door. If it encroaches on the fridge space, I hate to say it, but downsizing your hotplates might actually be the best option. Moving gas, electricity and water supply at this point is going to be a nightmare. I hope you can find a resolution you're happy with. What an absolute pain in the arse! Building with Dale Alcock Homes in Aveley Our thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=63880 And yes, my pants are indeed fancy. Re: Kelsey78’s First Home in Honeywood DAH Build- Kitchen Dr 386Dec 04, 2014 6:38 pm I think they should change your window to a splashback window giving you space for overhead cupboards and a place for your range hood. My build: viewtopic.php?f=31&t=68002 Re: Kelsey78’s First Home in Honeywood DAH Build- Kitchen Dr 387Dec 04, 2014 6:54 pm Burnsfirsttime I think they should change your window to a splashback window giving you space for overhead cupboards and a place for your range hood. Is there room to do this, Kelsey? It's a great idea. You could have a hidden rangehood in the overhead cupboards above the splash back window. Although I'm not sure what this would entail structurally. A lot of delays, not doubt. Good thinking Burnsfirsttime! Building with Dale Alcock Homes in Aveley Our thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=63880 And yes, my pants are indeed fancy. Re: Kelsey78’s First Home in Honeywood DAH Build- Kitchen Dr 388Dec 04, 2014 7:06 pm Splashback window sounds the best option to me too. Also keep in mind that fridges are often deeper than the space the builder provides so depending on your model you might find you have even less space than shown on the plan. My New Home Build with Dale Alcock - https://forum.homeone.com.au/viewtopic.php?f=31&t=66662 Landscape Design Thread - https://forum.homeone.com.au/viewtopic.php?f=19&t=71784 Re: Kelsey78’s First Home in Honeywood DAH Build- Kitchen Dr 389Dec 04, 2014 7:37 pm Yep I agree best option move the wall out Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=66620 Re: Kelsey78’s First Home in Honeywood DAH Build- Kitchen Dr 391Dec 04, 2014 9:35 pm Gosh Kelsey - everything is powering along! I have only just finished grey float! However - what a bummer about the hotplate - surely this is something they should know and the fact it's gone on so long is crazy. I also like the idea of the glass splash back (if possible) since that's how I am having my kitchen. I really hope DAH find a solution for you, one that suits you guys and doesn't take too long. Providence Estate - Wellard, WA - Ventura https://forum.homeone.com.au/viewtopic.php?f=31&t=68532 Pinterest (all selections): http://www.pinterest.com/aimees88/final-house-selections/ Re: Kelsey78’s First Home in Honeywood DAH Build- Kitchen Dr 392Dec 04, 2014 11:29 pm That's terrible Kelsey. I really feel for you. I pretty much grabbed my plans straight away to check as we have our hot plate in a similiar spot. I'm not sure if you've got enough room to move the wall? What would the distance be between the wall and your fridge and would the fridge door open and leave any room? As much as I like a glass splash back, the gas plumbing and other changes might be impossible. I know it's not your preference, but we redid our kitchen 3 years ago and put in a 700mm gas hotplate. It's really big enough and doesn't look out of place with our 900mm oven. Re: Kelsey78’s First Home in Honeywood DAH Build- Kitchen Dr 393Dec 04, 2014 11:55 pm fancy pants Moving the wall would be my preference too Kelsey, provided you can still easily open the refrigerator door. If it encroaches on the fridge space, I hate to say it, but downsizing your hotplates might actually be the best option. Moving gas, electricity and water supply at this point is going to be a nightmare. I hope you can find a resolution you're happy with. What an absolute pain in the arse! Thanks FP!! It all seems like a pain in the arse at this stage! I'm not confident there will be enough space with a 900mm space between the fridge and wall. Burnsfirsttime I think they should change your window to a splashback window giving you space for overhead cupboards and a place for your range hood. I really like this idea, I always did! We were deterred from this idea from our sales consultant due to the practicality of cleaning the window with all the food splashes, especially if we have blinds! But it seems like a good fix now especially if we add overheads! fancy pants Burnsfirsttime I think they should change your window to a splashback window giving you space for overhead cupboards and a place for your range hood. Is there room to do this, Kelsey? It's a great idea. You could have a hidden rangehood in the overhead cupboards above the splash back window. Although I'm not sure what this would entail structurally. A lot of delays, not doubt. Good thinking Burnsfirsttime! Defiantly lots of delay if we chose this option, we would need to get council approval and have our energy rating reassessed! justlearning Splashback window sounds the best option to me too. Also keep in mind that fridges are often deeper than the space the builder provides so depending on your model you might find you have even less space than shown on the plan. Yep this really concerns me! And what is worse is we measured the recess today and it is 60mm shorter than the plan!! What else could go wrong in that space!! Speedwaychick68 Yep I agree best option move the wall out I'm leaning towards this as I don't think we need approval for this! aimees88 Gosh Kelsey - everything is powering along! I have only just finished grey float! However - what a bummer about the hotplate - surely this is something they should know and the fact it's gone on so long is crazy. I also like the idea of the glass splash back (if possible) since that's how I am having my kitchen. I really hope DAH find a solution for you, one that suits you guys and doesn't take too long. That's Aimee, I really hope so too! Just when i thought things were flying we hit another hump! I'm not sure what I want to so anymore with this space! I'm just so confused! I wish I was told upfront so I didn't have to sacrifice anything like I am now D_rail That's terrible Kelsey. I really feel for you. I pretty much grabbed my plans straight away to check as we have our hot plate in a similiar spot. I'm not sure if you've got enough room to move the wall? What would the distance be between the wall and your fridge and would the fridge door open and leave any room? As much as I like a glass splash back, the gas plumbing and other changes might be impossible. I know it's not your preference, but we redid our kitchen 3 years ago and put in a 700mm gas hotplate. It's really big enough and doesn't look out of place with our 900mm oven. Thanks D_rail, I really hope you don't have the same issue as me! I think I'm going to sleep on it and see how I feel in the morning! It's all just to much at this point with all options! I really just want to be a big baby and not comprise but I know I'm going to have to make this decision very soon our a build will get held up. Dale Alcock Build in Honeywood Our Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70204&p=1154102#p1154102 Re: Kelsey78’s First Home in Honeywood DAH Build- Kitchen Dr 394Dec 05, 2014 12:07 am In other news our ceilings were installed today! Entry Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Entry to our ensuite and WIR Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Home theatre Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Living Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Dale Alcock Build in Honeywood Our Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70204&p=1154102#p1154102 Re: Kelsey78’s First Home in Honeywood DAH Build- Kitchen Dr 395Dec 05, 2014 12:21 am Just caught up on your thread. That is ridiculous that they couldn't pick up something like that when you were doing planning?! Surely they would have known the regulations... Anyway, I hope you come up with a solution soon. I think a 750mm would still look ok but I'd be the same and not want to compromise after their stuff up!! Onto the good news about the ceilings - woohoo!! It's all coming together Lockup is super duper close now xx Building our first home - https://forum.homeone.com.au/viewtopic.php?f=31&t=73568 Re: Kelsey78’s First Home in Honeywood DAH Build- Kitchen Dr 396Dec 05, 2014 12:22 am I can't help but be a bit jealous. Our guys are still doing the grey float. Haven't even started the outside yet! They've been at it for two weeks now. Good for you though. The ceilings look great. Bummer about the stove. My New Home Build with Dale Alcock - https://forum.homeone.com.au/viewtopic.php?f=31&t=66662 Landscape Design Thread - https://forum.homeone.com.au/viewtopic.php?f=19&t=71784 Re: Kelsey78’s First Home in Honeywood DAH Build- Kitchen Dr 397Dec 05, 2014 12:06 pm Meelz Just caught up on your thread. That is ridiculous that they couldn't pick up something like that when you were doing planning?! Surely they would have known the regulations... Anyway, I hope you come up with a solution soon. I think a 750mm would still look ok but I'd be the same and not want to compromise after their stuff up!! Onto the good news about the ceilings - woohoo!! It's all coming together Lockup is super duper close now xx Thanks Meelz! I still think it may be a long road before we have a resolution but I am hopeful we will be satisfied with the outcome. I’m just concerned about what it will do to the timeline. justlearning I can't help but be a bit jealous. Our guys are still doing the grey float. Haven't even started the outside yet! They've been at it for two weeks now. Good for you though. The ceilings look great. Bummer about the stove. I know that feeling to well, While we were waiting 9 and a half weeks for our brickwork to start, people who got slabs after us already had timbers going up. Don’t worry I’m sure they will catch-up over other stages of the build This is probably one of the bonuses about having a small house, things seem to get done alot quicker! Dale Alcock Build in Honeywood Our Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70204&p=1154102#p1154102 Re: Kelsey78’s First Home in Honeywood DAH Build- Cornices 398Dec 09, 2014 9:26 pm We have a few exciting updates today! Yesterday our roof capping was completed Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And our cornices were completed Kitchen Love our swan cornices! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ But most exciting of all is that we have been given a lock up date, December 16!!!! Before Christmas!!! Yay!!! We still haven't resolved our kitchen issues but I'm really hoping it won't interfere with our timeline too much! Dale Alcock Build in Honeywood Our Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70204&p=1154102#p1154102 Re: Kelsey78’s First Home in Honeywood DAH Build- Cornices 399Dec 09, 2014 9:28 pm Wow Kelsey it looks awesome! How exciting having a lock up date, u made it! Woohoo! Building our first home - https://forum.homeone.com.au/viewtopic.php?f=31&t=73568 Re: Kelsey78’s First Home in Honeywood DAH Build- Cornices 400Dec 09, 2014 9:35 pm Woohoo lock up before Christmas, what a nice present! Everything is looking amazing. Very annoying about the kitchen dilemma since its their job as a builder to know about these regulations and avoid these problems...right? I'm sure it will all get sorted out soon, hopefully with a solution everyone's happy with! Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 19869 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 47929 If you are in Victoria you have a statutory right to your own building inspector regardless of builder's consent. No negotiations are required. However the builder will… 1 3401 |
