Browse Forums Building A New House Re: Sahara Q1 - Outdoor Kitchen 3701Jul 30, 2016 12:20 pm Re: Sahara Q1 - Final Stage started 3702Sep 06, 2016 1:41 pm mirzOur tiler was working today on Sunday. It was a big surprise for me. We discussed misaligned tiles on the back and left hand side of bath tub with him. He acknowledged this as an issue and promised to fix it on his next trip (hopefully couple of days). A big thanks to Siapao for pointing this out. Laundry wall tiles Grout is now giving a neat look hey Mirz, Do you remember how much you paid for the laundry fitout? Re: Sahara Q1 - Outdoor Kitchen 3704Sep 07, 2016 9:54 am mirzit was around $1300 Oh wow!! Henley want a lot more than that for the palace! Re: Sahara Q1 - Outdoor Kitchen 3705Sep 11, 2016 1:34 pm Hi Mirz, I am new to this forum but I have learnt a lot from you from your blog.Thanks so much for sharing your experience.We are going to build Sahara Belle Q1 in melbourne eastern surburb. We are thinking to install evap cooling with henlry ad part of free promotion.however ,the evap cooling can be installed upstair only. I saw your post previously that you installed evap cooling for both upsair snd down stair post handover. Below are couple quick questions in regards of your evap cooling system. 1) how your evap cooling system for down stairs was installed? Are they sharing the same ducted heating vents for down stairs?or they have to install seperate cooling vents? 2) is the evap cooling system sufficient for the hot days? 35 degree plus? 3) i heard a lot people saying the evap cooling vdnts let the heating escape during winter. What is your experience? Looking forward for your input! Thanks a million! Nancy Re: Sahara Q1 - Outdoor Kitchen 3706Sep 12, 2016 1:59 pm Hi Mirz, I am new to this forum but I have learnt a lot from you from your blog.Thanks so much for sharing your experience.We are going to build Sahara Belle Q1 in melbourne eastern surburb. We are thinking to install evap cooling with henlry ad part of free promotion.however ,the evap cooling can be installed upstair only. I saw your post previously that you installed evap cooling for both upsair snd down stair post handover. Below are couple quick questions in regards of your evap cooling system. 1) how your evap cooling system for down stairs was installed? Are they sharing the same ducted heating vents for down stairs?or they have to install seperate cooling vents? 2) is the evap cooling system sufficient for the hot days? 35 degree plus? 3) i heard a lot people saying the evap cooling vdnts let the heating escape during winter. What is your experience? Looking forward for your input! Thanks a million! Nancy Hi As far as I know cooling and heating through the same ducts is possible for refrigerated cooling system only. Evaporative cooling requires large separate ducts. You can ask them to put extra vents downstairs as well but only possible if hollow straight pillars are coming through. They may be able to do one or two vents depends on the structural set up and capacity of Evaporative cooler. Cooling vents let heat out but you can manually close the vents to prevent it to an extent. Is Evaporative cooling sufficient enough is personal choice. I live in south east Melbourne and was ok last summer. Gets bit soggy when left for long periods. I am also building Sahara belle in south east. Which estate is yours. Regards Re: Sahara Q1 - Outdoor Kitchen 3708Sep 12, 2016 8:07 pm Hi Nancy, We have evaporative cooling upstairs only. There is no way to install evaporative cooling downstairs post handover. Only porter Davis provides couple of ducts downstairs if you build with them. No heat loss issues at all. Re: Sahara Q1 - Outdoor Kitchen 3709Sep 12, 2016 8:54 pm Thanks, Mirz. You are a legend ! How did you find last summer with your evaporative cooling system? Do you think you might need to install any split system downstairs for those really hot days? Do you have 5 outlets or 7 outlets ? I am thinking to upgrade from 5 outlets to 7 outlets so we can add an extra onr near stair case to grt the cool air to down stair a bit? Sorry for all the questions , i am bit struggling to the decisions at the moment. Sahara Q1 - Outdoor Kitchen 3710Sep 12, 2016 9:09 pm We got 4 ducts in bed rooms, 5th in TV room and 6th goes almost right above staircase. Master bed, tv room and staircase ducts are much bigger in size for higher air flow. It does a good job. But being evaporative, you will need to open windows downstairs to move cool air in required area. At least go with provision to have power points on external walls for split aircons. It will help you from running cables or conducts outside later on. Re: Sahara Q1 - Outdoor Kitchen 3712Sep 12, 2016 10:52 pm mirzHi Nancy, We have evaporative cooling upstairs only. There is no way to install evaporative cooling downstairs post handover. Only porter Davis provides couple of ducts downstairs if you build with them. No heat loss issues at all. Carslisle does it as well. Re: Sahara Q1 - happy ever after 3714Jan 19, 2017 1:16 pm HomeAssurance team is one of the best experience if you are building with Henley. They are attending each and every issue we raised, and following up to make all sorted and we are pleased with the outcome. I think, this is one of most important part of your life time investment and dream home. Re: Sahara Q1 - happy ever after 3715Jan 20, 2017 9:46 pm Hi Mirz, Great to hear from you and glad to hear you've settled in well. We have our 12 month inspection in a couple of weeks and hope to have a similar experience. cheers Michael ------------------------------------------- Build Thread - Mainvue Emporio ER430 KDR https://forum.homeone.com.au/viewtopic.php?f=31&t=76790&p=1332227&hilit=mainvue#p1332227 Re: Sahara Q1 - happy ever after 3716Feb 27, 2017 8:43 am Hi Mirz, Super informative reading - your doing a real community service!! We are looking at doing a KDB with Henley in the inner south, and we are getting a price of mid 4's for a 41 square Sahara. Thats with estimated site costs of 50, plus another 15 random zone charge. We have added aircon, higher ceilings etc. Does that seem in the ballpark, or should we be negotiating? Re: Sahara Q1 - happy ever after 3717Feb 27, 2017 11:12 am Hi Mirz, Super informative reading - your doing a real community service!! We are looking at doing a KDB with Henley in the inner south, and we are getting a price of mid 4's for a 41 square Sahara. Thats with estimated site costs of 50, plus another 15 random zone charge. We have added aircon, higher ceilings etc. Does that seem in the ballpark, or should we be negotiating? We are in the process of the Sahara 40 and its so far upto around 370k, but it all depends on what you are adding as well. That number seems to be fair to me considering our site costs are under 7k Re: Sahara Q1 - happy ever after 3718Feb 27, 2017 4:48 pm Thanks for the reply! So ex site costs and zone surchagre we are at about 391. Note that this is before any upgrades to standard finishes etc. Im wondering if anyone has any experience with zone charges? We really love the henley design and finish is pretty good, but the xtra $65 is kinda killing the budget! Re: Sahara Q1 - happy ever after 3719Feb 27, 2017 6:54 pm Thanks for the reply! So ex site costs and zone surchagre we are at about 391. Note that this is before any upgrades to standard finishes etc. Im wondering if anyone has any experience with zone charges? We really love the henley design and finish is pretty good, but the xtra $65 is kinda killing the budget! 391 seems a bit expensive have you added a facade into that? Or is it things like flooring, cooling etc bumping up the price? Re: Sahara Q1 - happy ever after 3720Feb 27, 2017 9:16 pm Faced is included in that (nothing to flashy, think its about 5k addon). Also includes upping ceiling heights, 5k for carpet, 10k for flooring, sink in butlers pantry etc. I think maybe I just underestimated the total cost of doing this!!! Fast beep or slow beep? If slow - And if the smoke alarm continues to beep once every 40 seconds after a new battery… 1 20098 Another update: my previous suggestion of the Reolink Altas PT Ultra - as good as that camera is, I stupidly got confused by all the extra bells and whistles this camera… 2 18929 Our PCI will be in 2 weeks and my own insurance need be ready on that day as well. I am starting to look around the insurance. This is my investiment property. After PCI,… 0 27075 |
