Browse Forums Building A New House Re: Building Arden homes Votivo 37 in South East 361Mar 21, 2018 5:45 pm 21/03/18 Confirmation received from SS for preplaster inspection on 23/03/18. Further temporary Front entry door and garage doors r in. follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 362Mar 21, 2018 5:47 pm 21/03/18 Confirmation received from SS for preplaster inspection on 23/03/18. Further temporary Front entry door and garage doors r in. Re: Building Arden homes Votivo 37 in South East 363Mar 21, 2018 6:11 pm Y follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 364Mar 21, 2018 6:13 pm 21/03/18 Confirmation received from SS for preplaster inspection on 23/03/18. Further temporary Front entry door and garage doors r in. R u sure - haven’t seen a single builder in our estate put final door up so early. Didn’t get time today but will put photo by Friday - it has no glass in it - all timber Have you had your pre-plaster follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 365Mar 21, 2018 6:28 pm Thanks firsttime - very much appreciated It also mentions in my drawings the same and also shows them external But they have covered it by hebel and the ducts r inside wall cavity Before hebel Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Will wait and see if they drill at the right place because they still have to add a vent for spa pump on first floor follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 366Mar 22, 2018 12:23 pm 22/03/18 went to site around 12 and noticed no activity - Temporary front door Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 367Mar 24, 2018 12:15 pm Re: Building Arden homes Votivo 37 in South East 368Mar 24, 2018 3:20 pm r u getting the front door painted or stained - going to estate soon and will check some other builds cos have seen some having these green looking doors follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 369Mar 24, 2018 3:43 pm r u getting the front door painted or stained - going to estate soon and will check some other builds cos have seen some having these green looking doors Green doors need to be painted. Re: Building Arden homes Votivo 37 in South East 370Mar 24, 2018 3:57 pm Maybe that could be the reason why they install them straight away rather than temp ones cos my garage doors r green follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 371Mar 24, 2018 4:00 pm Have visited the site along with private inspector yesterday for pre-plaster inspection and noticed that almost all cavity slider frames have been put the wrong way - we have them opening other side with light switch near the opening follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 372Mar 27, 2018 8:53 pm Have visited the site along with private inspector yesterday for pre-plaster inspection and noticed that almost all cavity slider frames have been put the wrong way - we have them opening other side with light switch near the opening How did the inspection go PE? Hopefully not too many issues. Seriously, don’t these trades read the plan or at least check over what they’ve done to make sure it’s correct. How did your house hold up with the recent rain? Someone removed one of our upstairs window and the rain got inside. Re: Building Arden homes Votivo 37 in South East 373Mar 27, 2018 9:10 pm firsttime_homies1401Have visited the site along with private inspector yesterday for pre-plaster inspection and noticed that almost all cavity slider frames have been put the wrong way - we have them opening other side with light switch near the opening How did the inspection go PE? Hopefully not too many issues. Seriously, don’t these trades read the plan or at least check over what they’ve done to make sure it’s correct. How did your house hold up with the recent rain? Someone removed one of our upstairs window and the rain got inside. I think around 45 points some from frame stage. Our first floor activity area window had a part missing and the rain water piled up leading it to seep through onto ground floor Also same issue with bedroom 2. Yes - it is amazing how they charge as if professional tradies and then despite keeping a booklet with instructions at some places they had to put 4 nails they put 2 nails and so on the list becomes long We had light switches put the side where you open the door and the CSD were put the other way around follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 374Apr 04, 2018 9:26 am Rumpus room CSD frame fitted and first floor rendering done during Easter break. follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 375Apr 05, 2018 8:35 pm 05/04/18 Eaves all around the house done. follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 376Apr 06, 2018 11:29 am So visited the site today morning for a walk thru with SS - rather 2 because a new SS has been assigned- Plaster work was going on - immediately told them that first floor CSD are to be moved around. Talked about moving the heating vent in bathroom on first floor to the empty space rather than on spa - both SS seemed not ready saying it affects the energy rating. follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 377Apr 06, 2018 11:55 am 05/04/18 Eaves all around the house done. Wow, I think you’ve overtaken us as we’ve only just had our bricks finished and no eaves yet. That’s great that you’ve done a walk through with both SS. Now there’s no excuse with your new SS saying he didn’t know or the other SS never told him about something. Re: Building Arden homes Votivo 37 in South East 378Apr 06, 2018 12:01 pm firsttime_homies140105/04/18 Eaves all around the house done. Wow, I think you’ve overtaken us as we’ve only just had our bricks finished and no eaves yet. That’s great that you’ve done a walk through with both SS. Now there’s no excuse with your new SS saying he didn’t know or the other SS never told him about something. Well u r still way ahead - the internal plastering only started today. The plastering started but I still haven’t received photos regarding around 44 issues which were to be fixed. The SS only said he has taken photos and will send them. Still awaiting them. follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 379Apr 06, 2018 2:27 pm firsttime_homies140105/04/18 Eaves all around the house done. Wow, I think you’ve overtaken us as we’ve only just had our bricks finished and no eaves yet. That’s great that you’ve done a walk through with both SS. Now there’s no excuse with your new SS saying he didn’t know or the other SS never told him about something. Well u r still way ahead - the internal plastering only started today. The plastering started but I still haven’t received photos regarding around 44 issues which were to be fixed. The SS only said he has taken photos and will send them. Still awaiting them. Have you got a reinspection or is your next scheduled inspection NHP? Keep reminding your SS and get it in writing that the defects have been fixed and there’s photo proof. Re: Building Arden homes Votivo 37 in South East 380Apr 06, 2018 8:59 pm Basically putting plaster is up for both levels Rumpus view from Alfresco Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Entrance Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Oof, that sounds like a classic East Brisbane curveball. Underground utilities can really throw a wrench into even the simplest builds. Have you looked into whether… 3 40929 Old Home Restoration / Renovation Thanks for the reply. I just moved to Melbourne so unfortunately don’t know many people around. Hence came to this forum hoping to find someone who had some feedback… 2 2337 Where are you located? Assuming Sydney or south? Speaking from experience, big windows create significant heat gain/loss even if they're double/triple glazed. I do still… 1 31615 |
