Sorry Norfolk, but not quite sure what you mean by the door. I don't see what you're talking about.
Browse Forums Building A New House Re: Metricon Sentosa 52 Modified 281Feb 29, 2020 2:54 pm Norfolk @freak_Zombie Check you kitchen island profile against the plans and the detailed kitchen company drawings that you signed off on. Also check your front door surrounds against the plans. It looks like a brick course maybe missing above it, replaced by a flimsy wooden 'storm' panel above the door frame. See picture of the bricks above my front door. If these features don't match your signed plans don't accept the Metricon SS's standard "it's a design detail" fob off. You are legal entitled to receive what you signed off on. BTW, on my place Metricon re-did the all kitchen cabinets because the original ones they installed overhung the long window, not to plan and looking shocking. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Sorry Norfolk, but not quite sure what you mean by the door. I don't see what you're talking about. Re: Metricon Sentosa 52 Modified 282Feb 29, 2020 3:04 pm Freak_Zombie In your photo it looks like there should be 3 layers of bricks above your front door. Not the 2 layers of bricks only and a wooden 'storm' panel to cover the (brick height) gap just above the door frame shown. I had this situation on my place. Some brickwork above the door was missing and was clearly not done to plan so I asked Metricon to rectify this defect by adding more bricks, and moving the supporting steel lintel down. Just check your plans as the design in your photo could be exactly what you agreed to. Also I could be wrong in interpreting your photo. I was pretty fussy, however you may consider its fine. Re: Metricon Sentosa 52 Modified 286Mar 01, 2020 1:53 pm freak_Zombie Here is the top of my laundry door. It's a standard height door like my front door. The bricks and horizontal mortar beds are standard heights, & within tolerances. Assuming your doors and bricks are of standard height, I believe your door openings' construction details should be the same. I'm interested in your SS's explanation. These deviations can be easily rectified by a bricklayer putting the missing layers in before PCI, if that's what you choose. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Metricon Sentosa 52 Modified 287Mar 02, 2020 11:38 am Agreed, top of the doors should be bricked. It's exactly the same mistake they made with your pergola height. Kitchen island is horrible too. How could they get it so wrong. Do you have drawings to back your design? Re: Metricon Sentosa 52 Modified 288Mar 02, 2020 9:32 pm Yeah I always felt that metal plate at the top feels odd and off. In fact almost all my sliding doors and doors have that metal plate. I'm confident I payed for the upgrade to have the areas above my window filled in with bricks. Thanks for your explanation guys. Meeting the site supervisor tomorrow. This information has helped quite a bit. Oh and my contract supervisor who didn't reply to my emails for over two weeks just left the company. Wow. Re: Metricon Sentosa 52 Modified 289Mar 03, 2020 8:45 am Now they are saying for my kitchen island, they are going by what is stated in the contract and not the floorplans. If that's the case why do I need to sign off on the floorplans then? Also it makes no mention in my contract that my waterfalls do not reach the floor. Re: Metricon Sentosa 52 Modified 294Mar 03, 2020 12:38 pm wow, this is never ending. I think you are going to have a battle on your hands to get this right.... but don't give up!!! Re: Metricon Sentosa 52 Modified 296Mar 03, 2020 1:38 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ That's my paperwork. What would metricon have that's different from the page I signed off on? How could they brazenly say they won't change the silestone for my kitchen island? Although I did mess up on the laminte panel, it's not supposed to look like that but regardless, the one they installed is 3.5cm thick instead of the 6cm on the floorplans. Re: Metricon Sentosa 52 Modified 298Mar 03, 2020 5:35 pm Freak_Zombie Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ That's my paperwork. What would metricon have that's different from the page I signed off on? How could they brazenly say they won't change the silestone for my kitchen island? Although I did mess up on the laminte panel, it's not supposed to look like that but regardless, the one they installed is 3.5cm thick instead of the 6cm on the floorplans. Just my 2 cents. That's not the end result you would have expected. I think if I just look at the floor plans without looking into the photo (the final design you wanted) then I think the current kitchen is very close except for the thickness you mentioned. May be the floor plan/contract should have had possible dimensions as - 1500x750x980 and an overhang of almost 400mm at the front ? Just my thoughts. That Tub tap is not acceptable and needs to be moved. Re: Metricon Sentosa 52 Modified 299Mar 04, 2020 6:21 am Ozshaz Freak_Zombie Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ That's my paperwork. What would metricon have that's different from the page I signed off on? How could they brazenly say they won't change the silestone for my kitchen island? Although I did mess up on the laminte panel, it's not supposed to look like that but regardless, the one they installed is 3.5cm thick instead of the 6cm on the floorplans. Just my 2 cents. That's not the end result you would have expected. I think if I just look at the floor plans without looking into the photo (the final design you wanted) then I think the current kitchen is very close except for the thickness you mentioned. May be the floor plan/contract should have had possible dimensions as - 1500x750x980 and an overhang of almost 400mm at the front ? Just my thoughts. That Tub tap is not acceptable and needs to be moved. Not really though. The stone work doesn't reach the floor like the floorplans. Plus it doesn't say in the contract there would be a gap for the kickstand. The site supervisor said the bathtub is and piping is fixed and doesn't know how they are going to fix it. 😱😭 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 12153 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 9548 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 19622 |
