Browse Forums Building A New House Re: Anyone else building at Piccadilly Estate, Riverstone? 263Nov 28, 2016 2:55 pm Titania71 We might have to place a retaining wall when we put our fence, dropped our garage by about 60cm. Hi , I am just wondering how you guys were able to draw up very specific conclusions.. 60 cms garage drop ? I guess we still don't have access to final contour and soil test report isn't it ? Without this will the builder be able to do a slab design ? Cheers Re: Anyone else building at Piccadilly Estate, Riverstone? 265Nov 29, 2016 12:26 pm First Home Buyer | Livingstone 22 Tender accepted 9/10/15 | Contract signed 30/10/15 | Colours selected 29/03/16 Re: Anyone else building at Piccadilly Estate, Riverstone? 275Dec 04, 2016 12:14 pm They're very pretty. Love the colours Would they be the same trees as the ones planted along Piccadilly St against the new houses? First Home Buyer | Livingstone 22 Tender accepted 9/10/15 | Contract signed 30/10/15 | Colours selected 29/03/16 Re: Anyone else building at Piccadilly Estate, Riverstone? 277Dec 06, 2016 8:42 pm Welcome AllisWell, Not sure regarding your question, best to check with council or your builder. Which is your lot? We are lot 71 Titania Street and our daughter has lot 70. Regards, Silvia Re: Anyone else building at Piccadilly Estate, Riverstone? 278Dec 06, 2016 9:26 pm AllisWell Hi All, Happy to join this forum. I have a blocked lad at Piccadilly Estate. Quick question : Mine is narrow block, can I build Zero lot home? I think you cannot build a zero lot home. I remember checking with the developers. Zero lot means using the full width of the lot and not leaving min 900 mm wide open space on sides ... I guess neighbours won't like either Re: Anyone else building at Piccadilly Estate, Riverstone? 279Dec 06, 2016 9:29 pm ozitzen AllisWell Hi All, Happy to join this forum. I have a blocked lad at Piccadilly Estate. Quick question : Mine is narrow block, can I build Zero lot home? I think you cannot build a zero lot home. I remember checking with the developers. Zero lot means using the full width of the lot and not leaving min 900 mm wide open space on sides ... I guess neighbours won't like either Ozitzen is correct. The estate isn't a zero lot estate which is what I was told. Re: Anyone else building at Piccadilly Estate, Riverstone? 280Dec 06, 2016 11:19 pm gemcee ozitzen AllisWell Hi All, Happy to join this forum. I have a blocked lad at Piccadilly Estate. Quick question : Mine is narrow block, can I build Zero lot home? I think you cannot build a zero lot home. I remember checking with the developers. Zero lot means using the full width of the lot and not leaving min 900 mm wide open space on sides ... I guess neighbours won't like either Ozitzen is correct. The estate isn't a zero lot estate which is what I was told. I think I can shed some light as mine is probably one of the narrowest blocks (10.5 mtr), I am building the house minus the second garage and not leaving the meter or so on the sides is not an option as the builder told me. A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 225957 Wish you all the best. Once you signed the contract, they will find millions excuses to charge you. And have seen their sites unfinished for a long time. 4 25711 |
